How do you solve a hard differential equation with an integrating factor?
7 replies · 17K views · last reply
anirudhreddy
A Hard differential equation!
Solve:
dy/dx = (x^2) + y
The rules of this forum requires you to show some working, so that we know where to begin helping.
Can you solve the homogeneneous equation: dy/dy - y = 0 ?
Can you find a particular integral?
That is a first order linear differential equation with constant coefficients- actually, it's about the easiest you could come up with. genneth suggested solving the "homogeneous equation" first. That would work.
But for linear first order equations, there is a standard formula for the "integrating factor". You could also use that.
relevant equation:
if [tex]\frac{dy(x)}{dx}+P(x)\,y(x) = Q(x)[/tex]
then
[tex]y(x) = e^{-\int P(\eta)\,d\eta} \int Q(x)\;e^{\int P(\xi)\,d\xi}\,dx[/tex]
if you understand this you probably understand how to do your problem :smile:
thx guys
so...
first i should write it in the form
dy/dx + (-1)y = (x^2)
is that right?
the next step into better understanding this is to prove the formula above...
Proof hint
The way I always proved this was to make the differential equation exact first. Then the rest is algebra; ahem, calculus.
dy/dx-y=x^2 is a good start
To make your integrating factor, you do Exp(integral(-1dx)) (i hope that makes sense). Work it from there and see where you get.
