How do you work out the wavelegth (Franck-Hertz experiment)?
In the Franck-Hertz experiment with potassium vapor, a significant drop in current occurs at 1.62V, indicating energy absorption. The energy change, delta E, is calculated as 1.62 eV, leading to the wavelength calculation using the formula lambda = hc/E. The correct wavelength for the spectral line is determined to be 767 nm, derived from the equation 1.24/eV. It is important to verify the constants used in calculations, such as Planck's constant and the speed of light, to ensure accuracy. Understanding these calculations is crucial for interpreting the emission spectrum of potassium.
birdnotbeing
In a Franck-Hertz experiment carried out with potassium vapour, it is found that the current falls off rapidly at an applied voltage of 1.62V. Calculate the wavelength of the expected spectral line in the emission spectrum of potassium when this voltage is reached.
E = hf = hc/lambda
delta E = 1.62 eV
lambda = hc/1.62 = 3.08x10^-25
According to a powerpoint, it should be 1.24/eV = 1.24/1.62 = 767nm (which is right). Where does 1.24 come from?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
