How Does a Capacitor Introduce Phase Delay in a Circuit?
  • Thread starter Thread starter PhysicsTest
    Capacitor Circuit
9 replies · 3K views · last reply
PhysicsTest
TL;DR
Understanding the phase delay
I simulated the below circuit to capture the phase delay between input voltage and output current in LTSpice
How do i measure the phase delay introduced due to capacitor?
The rule is that currents in a series circuit are ALWAYS in phase. So I'll ask you what can you conclude from that rule and the circuit you have drawn.
When you are using the term "delay" - which signals do you have in mind? Such a delay is the delay between two signals (voltage and/or current) resp. the corresponding phases of these signals,
When you remember your own definitions, you will know what you have to measure/simulate.
This would normally be done with sine waves, not square waves. This is because the phase delay depends on the signal frequency. A pulse waveform contains many frequencies. It still can have a phase shift, but it's complicated. So sine waves, which are a single frequency, often swept through a range to make a frequency response (Bode) plot, is what most EEs use.
In any case, you need to specify the conditions, like the input waveform, for phase delay to make sense.
PhysicsTest said:
TL;DR Summary: Understanding the phase delay
It looks like you are using a Transient Analysis -- that is not the type of analysis that you should use to see the Frequency Domain characteristics of a circuit. Have a look at this article, and let us know what a better SPICE analysis mode would be... :smile:
https://techweb.rohm.com/know-how/simulation/7916/
I am analyzing the circuit and will come up with the exact problem i am facing.
A square wave will charge a capacitor up as soon as it is applied because it is similar to direct current.
Are you wanting to test the time constant, tau, as it is charging?
More accurately, a square wave will start to charge up a capacitor with the initial application of the first pulse. Subsequent pulses alternately start to discharge it and recharge it... (see the OP's transient SPICE simulation):
As has been noted the term phase delay (better called phase lag) is defined as the response to a particular frequency sine wave. So your question is not well formulated. Please try again.
