- 29,714
- 21,566
Katy96 said:2Pi/60?
A poor guess. It's ##2\pi##. You could always have googled that!
The discussion revolves around a problem involving a glass fibre flywheel designed to store kinetic energy from buses during braking. The context includes calculations related to the maximum kinetic energy, moment of inertia, radius, and mass of the flywheel, as well as determining the mean frictional torque during a stop.
Participants have engaged in clarifying the kinetic energy concepts and unit conversions. Some have successfully calculated parts of the problem, while others are still grappling with the equations needed for subsequent sections. There is an ongoing exploration of how to approach the final part regarding mean frictional torque, with hints provided about using changes in kinetic energy and angular motion equations.
Participants note the importance of using consistent SI units for mass and speed to ensure accurate kinetic energy calculations. There is also mention of specific constraints in the problem, such as the requirement to answer sections in a given order and the implications of energy loss during the two-minute stop.
Katy96 said:2Pi/60?
Is editing a response as you type it a lost skill?Katy96 said:so how do I change 48km/h into m/s? never mind I got it now!
okay well do I just divide by 2pi? because I thought you would do 16000X2pi/60PeroK said:A poor guess. It's ##2\pi##. You could always have googled that!
Katy96 said:okay well do I just divide by 2pi? because I thought you would do 16000X2pi/60
when I did that I got the right answer so in part c do I use vmax=rωmax or do I use I=0.606mr2PeroK said:I see what you did. There are ##2\pi## radians in a revolution, so yes it's ##2\pi /60## to convert from revs per minute to radians per second.
Katy96 said:when I did that I got the right answer so in part c do I use vmax=rωmax or do I use I=0.606mr2
thanks.PeroK said:Does that give the right answer?
I'm going offline now. Good luck with the rest of it.
Katy96 said:e) Determine also the
Yes. It is quite the conundrum.Katy96 said:Its just part e I'm struggling on now
sorry it meant to say Determine also the mean frictional torque causing the slowing down in the two minute stop.jbriggs444 said:Yes. It is quite the conundrum.
Then there is a starting point. What is the change in KE?Katy96 said:this is what I know, i need to use the change in the KE to find the final angular speed
that's where I get stuckjbriggs444 said:Then there is a starting point. What is the change in KE?
