How does a laser rangefinder measure distances up to 20 km?
  • Thread starter Thread starter DariusP
    Laser Measure
Laser rangefinders, particularly military-grade models, can accurately measure distances up to 20 kilometers by utilizing high-intensity laser pulses that minimize the effects of atmospheric attenuation. Despite concerns about light being absorbed or scattered, under optimal conditions, the reflected signal can still be detected effectively. The technology allows for precise measurements, with some devices achieving accuracy within 3mm over a 1km distance. This capability is further demonstrated by the ability to measure distances to the moon, which is over 760,000 km away. Overall, measuring 20 km with a laser rangefinder is feasible due to advanced technology and favorable conditions.
DariusP
Hello, I've known about average laser rangefinders that we can use for domestic needs. They're relatively cheap and can measure up to 50 meters but that's about it.
However, I've read that military laser rangefinders are able to measure distances using light up to 20 kilometers. How is that possible? By Beer's law light should be attenuated exponentially when traversing some medium, so how does a light travel 40 kilometers and can still be deciphered out of noise? Surely they're not firing high intensity pulses for these measurements?
I've read about it here in the applications section: https://en.wikipedia.org/wiki/Laser_rangefinder
Science news on Phys.org
Likes Vanadium 50
DariusP said:
Summary: Laser rangefinder ability to measure long distances up to 20 km
easy ... they can fire a laser at the moon and get a good reflected signal to measure the distance accurately
over a return distance of more than 760,000 km, so why would 20 km be so difficult ?
Gear I work with can do an accuracy of 3mm over 1km ( 2km return path) with a 2mW laserDave
Likes vanhees71
so we never got a response from you
do you now see any reason for no difficulty measuring 20km ?
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
