How does a scintillator help determine muon lifetime?
  • Context: Undergrad
  • Thread starter Thread starter shadocat08
    Lifetime Muon
The discussion revolves around the use of scintillators to determine the lifetime of muons, focusing on the experimental setup, the processes involved in muon decay, and the challenges associated with accurately measuring the lifetime. Participants explore the technical aspects of the scintillator array and the implications of muon charge on the measurements.
  • Experimental/applied
  • One participant describes the need for multiple scintillators to confirm muon entry and stopping, detailing the setup required for accurate timing measurements.
  • Another participant explains that muon decay follows a Poisson process, suggesting that the time intervals between stopping and decaying can be modeled with an exponential distribution to measure the lifetime.
  • Concerns are raised about the charge sign of the muons, with one participant noting the different decay rates for positive and negative muons and their implications for the analysis.
  • Another participant emphasizes the importance of focusing on the specific problem presented by the original poster, suggesting that the charge of the muons may not be the primary issue in their experiment.
  • Discussions include the potential for negative muons to form muonic atoms in carbon, which could affect the measured lifetime due to their capture rates.
Participants express differing views on the relevance of muon charge and the specifics of the experimental setup. There is no consensus on the implications of negative muon capture rates or the necessity of distinguishing between positive and negative muons in this context.
Participants note the complexity of the experimental setup, including the need for proper shielding and discriminator settings to reduce background noise. There are also unresolved questions regarding the specific materials used in the scintillator and their effects on the measurements.
shadocat08
In lab, my partner and I are determining muon lifetime with a scintillator. I understand that the scintillator will help us find the average lifetime by measuring the difference between the time that a particle enters the scintillator and when in decays, but I am not able to figure out why this helps us find out the lifetime. All online sources I have found simply state this as a fact without going into the reasoning.
Your scintillator array needs to verify that a muon has entered the sensitive volume and has stopped. This usually requires at least 3 scintillators; Two scintillators, separated by ~10 cm or more of lead, copper, or other nonmagnetic high density material, in coincidence (10 nanoseconds or better) to determine the arrival of a minimum-ionizing particle. The coincidence circuit also needs a third scintillator in prompt anti-coincidence to verify that the stopping muon did indeed stop, and not exit the other side. All scintillator signals should be processed through a discriminator circuit so all minimum ionizing particles will produce a fixed amplitude output signal (NIM level (preferred) or a TTL signal). These three scintillators determine a "START" signal, which if possible is used to start a MCA (multichannel analyzer). The muon (probably a positive muon, more later) will decay with a positron with maximum energy of about 52 MeV. (See Michel rho parameter energy specrum in Fig. 1 in
http://arxiv.org/pdf/hep-ex/0311040v2
A fourth scintillator (maybe 10 by 10 by 20 cm) should be the sensitive volume in which the muon stops, and the mu-decay signal from this scintillator is used to generate a delayed STOP for the MCA. At first, the MCA oscillator should be set to advance the channel number count at ~50 nanoseconds per channel. So a 200-channel MCA would record about 10 microseconds (~5 lifetimes) of delay time.
Both positive and negative muons will stop in the stopping volume. Negative muons will form muonic atoms and likely form muonic (atomic) atoms and get captured by the nuclei in the stopping volume. These muons will give an anomalously short decay time (under 1 microsecond, if stopping volume material is over Z ~26).
The discriminator level on the stopping volume scintillator should be set to detect all electrons over ~ 10 MeV (See Fig. 1 above).
There will be a lot of background counts in all scintillators, especially the one used for the stopping volume. This whole setup will need to be well shielded with non-radioactive-contaminated high density material (lead or copper). Ideally, the background counting rate in the stopping volume scintillator is less that 1000 random singles counts per second (This is the most difficult shielding problem). This will assure that only ~1% of the STOP signals will be due to random background.
You need to be especially careful to properly set the discriminator thresholds properly. For a 10-cm thick stopping volume discriminator, it should be able to detect all non-stopping minimum ionizing muons (~ 20 MeV signal) when the prompt anti-coincidence signal is put into prompt coincidence with #s 1 and 2..
A simpler setup is to use the stopping-volume scintillator for both the MCA START and STOP signal. You will still need to set the discriminator sensitivity threshold with minimum ionizing particles (like cosmic rays).
What scintillators, phototubes, fast electronics, and MCA do you have?
Good luck. I hope this helps.
Bob S
Here you have to understand the process of muons' decaying. Muon has a meanlifetime. It can decay at any time, which is a poisson process. With some calculation, you will find that the time interval between a muon stopping and its decaying abide by an exponential distribution. Fitting the distribution, and you will measure muon's lifetime. I hope it will help you. I used to do this experiment in our lab. It took me many days and nights. Good luck to you!
If you do not determine the charge sign of the stopping muon, you will need to include in your analysis the decay rate of positive muons, with a decay rate of about 4.56 x 105 sec-1, and the capture rate of negative muons captured in muonic carbon atoms, with an estimated capture rate of 3.76 x 104 sec-1. See for example Equations (3.1) through (3.6) in
http://www.cs.cmu.edu/~byl/publications/phys410 lab2 report.pdf
Bob S
Let's try and focus, please? The OP's problem is clearly not that he has positive and negative muons, and it is highly unlikely that his scintillator is made out of iron. (Z=26)
The OP does not state where the muons come from. They do state that they are being stopped in scintillator (mostly carbon). Unless they produce the muons in an accelerator and have a magnetic focusing channel, the ratio of positive to negative muons is nearly one. In cosmic rays it is ~1.27:1. See
Furthermore, in scintillator the negative muons form muonic (atomic) carbon atoms (the main component of scintillator). the capture rate in carbon, stated in the above URL and in the above post #4, is ~3.76 x 104 sec-1. This will reduce the measured lifetime.
Here is a quote from
http://www.fisica.unlp.edu.ar/~veiga/experiments.html
"[Muon] Charge ratio can be estimated to be µ+/µ- = 1.2 (45% µ- and 55% µ+) and lifetime due to nuclear capture in carbon is aprox 1.93 μs (0.142 μs in iron). And we will measure both: 2.2 μs x 0.55 + 1.9 μs x 0.45 = 2.065 μs."
The 1.93 μs stated lifetime for µ- in carbon yields 6.2 x 104 sec-1 capture rate for µ- in carbon.
Very clearly, the capture rate stated in the post #4 represents the capture rate in carbon, not iron.
Bob S
  • · Replies 17 ·
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 28 ·
  • · Replies 17 ·
