- 29,907
- 21,796
Yes, that looks right to me.Hak said:Excuse me, but I cannot see what you are saying. Could you check my result in post #101 and tell me where I am wrong? Thank you very much.
Okay, but how to make my equation for force per unit mass visibly proportional to ##\frac{m}{M}##? In the case where ## m \ll M##, how would such an equation become?PeroK said:Yes, that looks right to me.
That's with the simplifications using ##\frac m M \ll 1##. There's a discussion about whether that's a valid approximation to make in this case.Hak said:Okay, but how to make my equation for force per unit mass visibly proportional to ##\frac{m}{M}##? In the case where ## m \ll M##, how would such an equation become?
Sorry to bother you, but I didn't understand very well, I understood only partially.PeroK said:That's with the simplifications using ##\frac m M \ll 1##. There's a discussion about whether that's a valid approximation to make in this case.
Don't worry about it. The thread has 125 posts already!Hak said:Sorry to bother you, but I didn't understand very well, I understood only partially.
So?PeroK said:Don't worry about it. The thread has 125 posts already!
Not sure what you are asking. You have established ##\omega\approx\frac{5mv}{2MR}## and ##F\approx mR\omega^2##. Put those together.Hak said:Okay, but how to make my equation for force per unit mass visibly proportional to ##\frac{m}{M}##? In the case where ## m \ll M##, how would such an equation become?
Thank you, I understand now. So, the force ##F## is not approximate to ##0## when ## m \ll m## as was said previously, right?haruspex said:Not sure what you are asking. You have established ##\omega\approx\frac{5mv}{2MR}## and ##F\approx mR\omega^2##. Put those together.
It's right unless I made the same mistake as you.PeroK said:The idea is that I have got a formula for ##F## in terms of ##m, M, v, R##. If I post that formula, then I've given you the answer. But, if I plug ##M = 9m## into that formula and simplify, then that gives you something to check. It also gives the others something to check and they can confirm whether I've got it right or not. I think it's right, but we all make mistakes.
But, not really a mistake. I unwittingly made the simplification ##d \approx R##. Which is significant if we take ##\mu = 0.1##, which is too large for the simplifications to be valid.kuruman said:It's right unless I I made the same mistake as you.
Just plug in the numbers!Hak said:I did, but I didn't understand the percentages you set up.
Funny thing, I did too. My corrected exact value for ##\omega## when ##M=9m## is $$\omega =\frac{1}{5}\frac{v}{R}.$$It turns out that no approximation is needed if one uses the simplified moment of inertia in post#128.PeroK said:But, not really a mistake. I unwittingly made the simplification ##d \approx R##. Which is significant if we take ##\mu = 0.1##, which is too large for the simplifications to be valid.
Sorry to bother you again, could you explain this assumption better? Thank you for your patience, sorry again.kuruman said:Funny thing, I did too. My corrected exact value for ##\omega## when ##M=9m## is $$\omega =\frac{1}{25}\frac{v}{R}.$$It turns out that no approximation is needed if one uses the simplified moment of inertia in post#128.
The OP got the answer in post #101. The problem is solved. But, the thread goes on!kuruman said:It's not an assumption. I am following @PeroK's lead in post#95. I derived an expression for ##\omega## that I think is correct, I plugged in ##M=9m## and simplified. This allows for other users to check their answers against mine without anyone giving the answer away which is against our rules.
I did not understand the final part of the message. I simply meant to say that I am not clear about the distinction between generic values and approximate values in your expressions of ##\omega##, ##I_{cm}## and ##F##. If you feel like explaining it to me, I thank you very much.kuruman said:It's not an assumption. I am following @PeroK's lead in post#95. I derived an expression for ##\omega## that I think is correct, I plugged in ##M=9m## and simplified. This allows for other users to check their answers against mine without anyone giving the answer away which is against our rules.
I would like to know something about this request. Do you have any additional ideas about possible applications of this problem?Hak said:Okay, thank you very much. I have one more question: is it possible to make after-the-fact observations on this problem, some interesting notes or whatever? I have noticed that for other problems here on the Forum, very interesting observations have been made by you in addition to the final result.
My goal is not just to solve the problem, but to understand what is behind that problem, how many different ways it can be solved, and what and how many observations can be made in retrospect. So I try to learn as much information as I can from those who know more about the subject than I do. Sorry if I come across as annoying in asking all the time, it is just for good purposes.PeroK said:The OP got the answer in post #101. The problem is solved. But, the thread goes on!
You found an expression for ##\omega## in post #101.Hak said:I did not understand the final part of the message. I simply meant to say that I am not clear about the distinction between generic values and approximate values in your expressions of ##\omega##, ##I_{cm}## and ##F##. If you feel like explaining it to me, I thank you very much.
What do you get when you substitute ##M=9m##?Hak said:Following the procedure described by @kuruman in post #55, I find that ##\omega = \frac{5mv}{(2M + 7m) R}##
Do you have any tips?Hak said:I would like to know something about this request. Do you have any additional ideas about possible applications of this problem?
I have a doubt. In post #50, I calculated the linear momentum equation, which @erobz found to be correct in post #51.Hak said:Is ##mv = M v' + m (v'+ \omega R)## correct? All this is irrelevant for calculating the force ##F##, right?
The theory we were laboring under there was updated 5 posts later. Have you properly updated the linear momentum equation?Hak said:I have a doubt. In post #50, I calculated the linear momentum equation, which @erobz found to be correct in post #51.
Nevertheless, however, if we calculate the angular momentum with respect to the center of the asteroid of mass ##M##, we have that:
$$L_{before} = mvR$$
$$L_{after} = L_{cm} + y_{cm} V_{cm} (m+M)$$, where:
$$L_{cm} = I_{cm} \ \omega$$,
$$y_{cm} = \frac{m}{M+m}R$$ , obtained by placing an axis of reference ##Oxy## centered in the center of the large sphere,
$$V_{cm} = \frac{m}{M+m}v$$, obtained from equation ##(1) \ mv = (m+M) V_{cm}##.
Equalizing ##L_{before}## and ##L_{after}##, we obtain ##mvd = I_{cm} \omega##, the same equation calculated by @kuruman in post #55.
So, why is there discordance between the equation in post #50 and the equation (1) I reported in this post?
