How does centripetal force affects the path?
A charged particle moves in a circular path within a magnetic field due to the perpendicular nature of the magnetic force, which alters the particle's direction without changing its speed. The consistent inward force maintains a constant radius, resulting in a perfect circle rather than a spiral. If the force were to vary over time, various paths such as spirals or ellipses could emerge, but with constant force, the path remains circular. This concept is analogous to a car maintaining a circular path when the steering wheel is held steady at a constant speed. Understanding these dynamics clarifies why charged particles exhibit circular motion in magnetic fields.
jaobyccdee
When there's magnetic field, a charged particle moves in a circle. I would like to ask why won't the circle goes smaller even when there's a force pointing inward (towards the center of the circle). Thank you!
Any force that acts perpendicularly to the direction of motion doesn't change a particle's speed, only the direction. And the magnetic force always acts perpendicularly to the direction of motion.
So when it changes the direction of the path, why will it become a perfect circle instead of a path that circles around closer and closer to the center? Sorry i don't know the word to describe that path...
The word you're looking for is spiral. The reason the path is a circle in this case is because the force (and acceleration) are constant as well as perpendicular to the path (velocity). If the amount of force varies with time, then just about any path would be possible, with the only constraint that speed is constant. The force could be adjusted to create a spiral, an ellipse, a parabola, a hyperbola, a sine wave, ... , any path that is possible with constant speed and only direction changes. For example, think of the possible paths your car could follow while moving at constant speed with just steering inputs, however if you hold the steering wheel in one position, then the car's path will be a circle (or a straight line) (assuming it doesn't slide).
Thank you:)
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
