How Does Distribution Coefficient Affect Solvent Extraction Efficiency?
The distribution coefficient (k) of 7.3 indicates that solute A partitions favorably into dichloromethane (dich.) compared to water. In a single extraction with 100 mL of dich., approximately 8.8 g of A can be extracted from a 10 g solution in 100 mL of water, leaving about 1.2 g in the aqueous phase. For three successive extractions using 33 mL portions of dich., around 9.04 g of A can be removed, achieving about 94% extraction efficiency. To remove 98.5% of A in a single extraction, calculations suggest a substantial volume of dich. is required, although specific values are not finalized. Overall, the distribution coefficient significantly influences the efficiency of solvent extraction processes.
dingol
Extraction efficiency problem PLease help...
The distribution coefficient, k = (conc. in CH2Cl2/conc in H2O), between dichloromethane and water for solute A is 7.3.
What weight of A would be removed from a solution of 10 g of A in 100 mL of water by a single extraction with 100 mL of dichloromethane?
What weight of A would be removed by three successive extractions with 33 mL portions of dichloromethane?
How much dichloromethane would be required to remove 98.5% of A in a single extraction?
is this method right>>?>??
Basic numbers :
10 g of A total
100 ml of H2O, 100 ml of dichloromethan ( Iwilll abbreviate as dich.)
10 g of A in 100 ml of h2o by a single extraction w/ 100 mL of dich.?
if (x) g = the amount that stays in the water, 7.3(x)g of A must go into dich. phase.
Wt. of A in Dich. = 100 ml * 7.3(x)g/ml = 730 (x)g
Wt. of A in H2O = 100ml * (x) g/ml = 100(x)g
Total weight of A = 10 g (now partitioned between two layers)
add 100 (x) g + 730(x)g = 830 (x)g
830 (x)g = 10g
(x) = .0120481928
now, plugging x back into the equations:
wt. of A in Dich. = 730 (.0120481928)g = 8.7965 g
wt. of A in H20 = 100 (.0120481928)g = 1.205 g
Pt. 2: what weight og A owuld be removed by 3 successive extractions with 33 ml portions of Dich.?
Everything is the same, except instead of one extraction there will be 3 extractions with 33 mL portion s of dich. instead of 100 mL.
Wt. of A in dich. = (33mL)(7.3)(x)g/mL = 240.9 (x)g
Wt. of A in H20 = 100mL (x)g/ml = 100 (x) g
Total weight = 10 g
after adding 100 x + 240.9 x = 340.9 x
340.9(x)g = 10 g
x= 0.0293341156
after substituting back into equations:
Wt. of A in dich. = (33mL)(7.3)(.0293341156)g/mL = 6.824697g
Wt. of A in H20 = 100mL (.0293341156)g/ml = 2.83341156 g
DIch. later is removed. and second round begins
Wt. of A in dich. = 240.9g
wt. of A in H20 = 100g
total wieght = 2.833 g
340.9 (x)g = 2.833g
(x) = .0083103549
Weight of A in Dich. = 240.9 (.0083103549) = 1.99947g
weight of A in H2O = 100 (.0083103549) = .86103549g
Now layer is removed and third round begins
weight of A in Dich. = 240.9
Wt. of A in water = 100
total weight = 340.9
there fore,
340.9 x = .83g
x= .00243g
wt. of A in dich = 240.9 * .00243g = .5855387g
wt. of A in H2o = 100 * .00243g = .243g
total % weight = 6.825 + 1.999+ .5855 = 9.04095 from 10 g
(9.04095 / 10) * (100%) = 94%
continuation
Pt 3:
How much dich. would be required to remove from 98.5% of A in a single extraction?
98.5% = 9.85g of total weight of A in dichloro
wt. of A in Dich = (x)(y) = .985g
x= x
y = orig wt. of dich.
z = x*y
z= 10g
wt. of A in Dich. = y * 7.3x = y7.3 x
wt. of A in water = 100mL * 7.3 x = 730x
to be continued...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
