Intersting thread, I'm glad you keep asking questions but I think you don't understand some of the factors that are involved.
andrewbb said:
That explanation of evaporation is good, but doesn't describe the detail at the molecular level.
Water molecules are polar which means they are basically tiny magnets. The two hydrogen atoms sit on one side of the oxygen atom creating a positive charge on one side and negative on the other.
For a single molecule to evaporate it must overcome the cohesive force of the water (hydrogen bond). Hydrogen bonds are essentially magnetism. (The hydrogen is electromagnetically attracted to the oxygen in another molecule.)
You must misunderstand hydrogen bonding.
Oxegen atoms have a high electronegativity with a positive charge coming from it's 8 protons. When it forms a covalent bond with two Hydrogen atoms to form a water molecule, the attraction of all those protons "pulls" the electrons from the Hydrogen close towards it, resulting in a
slight negative charge at this end of the water molecule. Conversely, the two Hydrogen molecules respective electrons are slightly displaced away from the single proton that "holds" them resulting in each H atom gaining a
slight net positive charge.
This is the basis for Hydrogen bonding, the slightly positive hyrogen of one water molecule is attracted to the negative Oxygen of a neighbouring molecule. However, this hydrogen bond is about
one-tenth as strong as a covalent bond (source:
https://www.amazon.com/dp/0716798565/?tag=pfamazon01-20 Chap. 2&3). Also, the water molecules are continually breaking and re-forming hydrogen bonds due to their inherent motion. At anyone time a water molecule has around 3-4 hydrogen bonds formed but these quickly dissipate & reform with other molecules. This property is part of the reason why water has such a high boiling point, more heat energy is required to break these bonds.
andrewbb said:
While heat excites the molecules and churns them more vigorously, evaporation can happen in two ways:
1. two water molecules align so their oxygens repel from each other.
2. a water molecule hydrogen bonds to a molecule or atom in the air.
Does anyone have an argument to that way of looking at it? We are talking about the same thing, I am merely describing what happens to the individual water molecules. The temperature is a measurement of how vigorously the molecules are moving. If the molecules are moving around more vigorously, their hydrogen bonds are more likely to be broken which allows them to escape into the air.
Again, you assume that hydrogen bonds are like crazy magnetized forces. They are relatively weak but the huge accumulation of them is what gives water such a high boiling point. The molecular motion is too fast to sustain such bonds
due to the kinetic energy of motion they have. Also, if you re-read that statement about molecules choosing the shortest path you'll see that most molecules will not interact
in a mickey mouse shape and even if they do the natural repulsion of two molecules rebounding after
"collision" would barely be influenced compared to the kinetic speeds.
When water freezes it is due to the molecules kinetic energy slowing to the point where more than the standard 3-4 hydrogen bonds can form, but they still break & re-form. To assume that's false is to say that atoms become stagnant when water freezes & that's wrong for so many reasons...
Char. Limit said:
Water molecules are kind of small. Their motion is random, and as you get more and more of them (your water glass holds probably close to 10^25 water molecules) their random motion cancels itself out and tends to 0. In short, each water molecule is moving really fast, but they are all moving in random directions and cancel each other out, motion-wise.
This is the essence of Brownian Motion, [Read Einsteins paper on Brownian motion for more information - but this paper/reasoning is held as a proof for the existence of atoms], there are displacements on either side of a molecule at any particular time and this is "empty" space which is room for another molecule to fly into with kinetic energy to bounce another molecule. All throughout a glass of water they would roughly cancel out but at the top those molecules would fly out. There would be no water molecules of roughly equal kinetic energy to counteract this force. Again, it depends on environmental pressure & the kinetic energy of the particle, [I'll explain why environmental pressure is valid further down].
Furthermore, there wouldn't be as many hydrogen bonds forming with those molecules at the top of a glass of water. You can see that only the bottom half of the circumference of an imagined circular molecule is exposed to those water molecules underneath, the top half is exposed to the air molecules. Well, water molecules are the same.
idk the detail but let's assume half of the amount of hydrogen bonds are formed due to half of the surface area being exposed.
Hydrogen bonding is still a weak force & the kinetic energy of even the odd "ice-water molecules" is enough to overcome this. I'll repeat, it's
the accumulation of hydrogen bonding throughout a glass of water that gives it it's "strength", individual ones are pretty weak.
On average, the molecules in a glass of water do not have enough heat energy to escape from the liquid, or else the liquid would turn into vapor quickly (see boiling point). When the molecules collide, they transfer energy to each other in varying degrees, based on how they collide. Sometimes the transfer is so one-sided for a molecule near the surface that it ends up with enough energy to escape.
Source:
http://en.wikipedia.org/wiki/Evaporation
So, to be clear. If hydrogen bonds were such an important factor they would have to be stronger than they actually are & the fact that roughly half of the normal amount of Hydrogen bonds are capable of forming doesn't help.
Another really substantial claim in this thread which you didn't really address is why
hydrophobic substances such as oil evaporate. How could hydrogen bonding explain how substances that share similar electronegativity to that of a water molecule (causing them to cluster when immersed in water & not interact with said water) evaporate due to hydrogen bonds when they simply do not form for these molecules?. You'll see below that atmospheric conditions (by these I mean, what's above the water - be it a vacuum or air) are important & contribute to all liquids that will evaporate.
I believe this is further proof to the molecular kinetic energy being the main factor. As Dave said earlier, Hydrogen bonds are merely a contributing factor... So these electromagnetic forces you keep mentioning are hydrogen bonds, well I hope you can put that idea to rest now. You also never mentioned anything like Van Der Walls forces, but I assume that's because you know they are
far too weak to be of significance here.
The boiling point of an element or a substance is the temperature at which the vapor pressure of the liquid equals the environmental pressure surrounding the liquid.[1][2] A liquid in a vacuum environment has a lower boiling point than when the liquid is at atmospheric pressure. A liquid in a high pressure environment has a higher boiling point than when the liquid is at atmospheric pressure. In other words, the boiling point of liquids varies with and depends upon the surrounding environmental pressure.
-----From
http://en.wikipedia.org/wiki/Boiling_point
This quote from wikipedia gives insight to some of the claims made on this thread,
hamster143 said:
Air is irrelevant. You'll observe evaporation even in the vacuum.
Char. Limit said:
1. Water is polar, yes. But for the most part, air isn't (99% of air is nonpolar N2 and O2). How can a water molecule attach to a floating air particle when there is nothing to support it?
2. A water molecule is lighter than air, yes. But the only polar component of air that I can think of is... other water molecules. And that's about 1 part in 300. The attached water and "air" molecule would be heavier than the molecular mass of air.
So, how could a weak polar bond form between the odd single water molecule in air and a water molecule in a glass moving with a good bit of energy?
http://www.youtube.com/watch?v=zz4KbvF_X-0&feature=SeriesPlayList&p=166048DD75B05C0D This video gives you an idea of the energies the molecules have/need at specific temeratures. For a particle in the water to be "pulled" out by a single hydrogen bond with a H20 molecule in the air the force of attraction would have to be greater than the few Hydrogen bonds formed underneath this surface water molecule in the glass pulling it down, (if that's how evaporation occurred)...
I believe air pressure matters as the molecules of air above the glass would provide a repellant force down on these water molecules on the top of the glass flying up into them. Wouldn't that account for the temperature needing to be higher for these molecules to escape?
Wouldn't the water molecules require higher heat energy in order to gain a higher kinetic energy to overcome the downward force caused by the air above & the natural tendency for the water molecules to remain in the glass?
Doesn't that also show is why the temperature required for evaporation to occur in vacuo is lower?
andrewbb said:
What specifically is vibrating in the atom/molecule? As temperature increases, is the electron shell expanding? If so, then the electrical negativity charge on the atom would increase due to the proton(s) being of less influence. This would cause greater separation of the atoms/molecules at higher temperatures. Therefore the strength of electromagnetic charge is a function of temperature. Now, THAT makes sense in understanding thermal motion.
Do you understand electron shells, nevermind expanding ones...? If an electron shell were to expand wouldn't that mean the electrons would have to invent enough energy to overcome the attraction of the protons in it's nucleus, or to overcome the attraction of another atoms protons in a covalent bond? I'm not sure, hopefully somebody could answer that one for me...
DaleSpam said:
Actually, the orientation is pretty much irrelvant. If two otherwise isolated water molecules collide with low enough kinetic energy to form a hydrogen bond then they will simply rotate into the minimum energy orientation regardless of their initial orientation. They are not constrained to always maintain a certain orientation.
Also, the dipole field of a water atom is electrostatic, not magnetic. If it were magnetic then water would jump onto a magnet.
That is a very interesting thing I didn't know, this minimum energy orientation thing reminds me of Snell's Law, the snippets I could unerstand from Introductory chapters on Lagrangian Dynamics & stuff Feynman wrote about in the sum over histories stuff (I vaguely recollect from Hawking book, or somewhere like that
). Basically choosing the shortest & easiest path. I hope to find out more about this in the future.
This is the way I see the process, if I've made an error please try to correct me constructively, and with a source if possible.
