dkajsdk
- 5
- 0
A block of mass m = 0.500 kg rests on top of a block of mass M = 2.50 kg which is on the
floor. A string attached to the block of mass M is pulled so that its tension is T = 7.00 N
at a 25.0o angle to the horizontal as shown. The blocks move together across the
horizontal surface. The coefficient of static friction at the surface between the blocks is
μs = 0.410. There is no friction at the surface between block M and the floor.
a) What is the acceleration of the two-block system?
b) What is magnitude and direction of the total force (combination of normal force
and frictional force) on block m due to block M?
c) The tension T is now increased - what is the maximum tension, Tmax, with which
the string can be pulled such that the blocks continue to move together (i.e. that
the block of mass m does not start to slide on top of the block of mass M)?
I solved part a and got 2.11 m/s^2 but i have no clue about part b and c. please help me.
