How Does Gauss's Law Affect the Red Dot in This Scenario?
  • Thread starter Thread starter wiredGuy
    Gauss's law Law
Gauss's law indicates that a conductor can shield charges from each other, as demonstrated in the scenarios presented. In the lower scenario, the electric field from the green dot influences the outer surface of the conductor, but the red dot remains unaffected. Conversely, in the upper scenario, both the red and green dots are shielded from each other, resulting in no interaction between them. The charge distribution on the conductor's surface ensures that the electric fields cancel out, preventing movement of the red dot. This discussion highlights the effectiveness of Gauss's law in explaining charge interactions within conductors.
wiredGuy
I had a question regarding how Gauss's law works. I have attached an image that depicts two scenarios.
Basically, if you assume the blue lines are a conductor and the green and red dots both contain an equal amount of charge, what is the expected behavior of the red dot?
As I understand it, in the lower scenario, Gauss's law allows the blue conductor to shield the red dot from the green dot; thus, nothing happens to the red dot. What happens in the second scenario? (The one I drew above) Does the red dot remain where it is or move away -- and please explain why..
Thanks,
- Wired Guy.
What happens is that, the charge distributes in such a way so that the electric field due to the induced charges on the inner surface of the conductor cancels exactly with the field due to the charge inside the cavity, at all points in the conductor.
So, the two charges inside the cavity won't expereince the field of each other and won't move.
So in the second case the green dot moves while the red dot remains in the same place?
I was curious if the charges that move to cancel out the effects of the green charge were on the external or internal surface of the cage. Could you also refer me to a place where I can read more about this phenomena?
Thanks in advanced,
- Wired Guy
Are there parts of my question that are unclear? or is this the wrong forum to be asking the question on? (Generally I find the feedback to be much more active on this board).
In the lower scenario the field from the green dot affects the charge distribution on the outer surface of the conductor, but the conductor itself shields the red dot from being affected by the field of the green dot.
In the upper scenario both dots are shielded from each other. Neither dot is affected by the presence of the other.
The feedback is usually more active. I'm sorry I couldn't reply and left this hanging. I was traveling.
Thanks for stepping in Doc Al :smile:
Thanks for the help guys!
