How Does Integration by Parts Solve the Integral of Tanh(x)/(xe^x)?
  • Context: MHB
  • Thread starter Thread starter alyafey22
    Integral
The discussion revolves around the evaluation of the integral $$ \int^{\infty}_0 \frac{\tanh(x)}{xe^x} \, dx $$ using various mathematical techniques, including differentiation under the integral sign and alternative methods of integration. Participants explore different approaches to tackle the problem without reaching a consensus on a single method.
  • One participant proposes using differentiation under the integral sign to transform the integral into a different form involving the Digamma function.
  • Another participant suggests an alternative method that avoids differentiation under the integral sign, involving a double integral and series expansion.
  • There is a discussion about the validity and applicability of the methods used, with one participant humorously questioning the use of differentiation under the integral sign by physicists.
  • Both methods lead to expressions involving the Gamma function, but the participants do not agree on which method is superior or more appropriate.
Participants express differing opinions on the methods used to evaluate the integral, with no consensus reached on a preferred approach. Each method has its proponents, and the discussion remains unresolved regarding the best technique.
The discussion includes complex mathematical expressions and transformations that may depend on specific assumptions about convergence and the properties of the functions involved. Some steps in the derivations are not fully resolved, leaving room for further exploration.
alyafey22
MHB
$$ \int^{\infty}_0 \frac{\tanh(x) }{xe^x} \, dx $$
$\tanh(x) \text{ is the tangent hyperbolic function }$
Cool Problem!(Drunk)
I will solve this using differentiation under the integral sign.
The integral can be written in another form
$$ \int_0^\infty \frac{\tanh(x)}{x e^x}dx = \int_0^1 \frac{t^2-1}{(t^2+1)\ln t}dt$$
Let us define
$$ I(\alpha) = \int_0^1 \frac{t^\alpha-1}{(t^2+1)\ln t}dt$$
$$\begin{aligned} I'(\alpha) &= \int_0^1 \frac{t^\alpha}{t^2+1}dt \\ &= \int_0^1 t^\alpha \sum_{k=0}^{\infty}(-1)^k t^{2k} \ dt \\ &= \sum_{k=0}^\infty (-1)^k \int_0^1 t^{\alpha + 2k}\ dt \\ &= \sum_{k=0}^\infty \frac{(-1)^k}{\alpha +2k+1} \\ &= \frac{1}{\alpha+1}\sum_{k=0}^\infty \frac{(-1)^k}{1+\left( \dfrac{2}{\alpha + 1}\right)k} \\ &= \frac{1}{4}\left\{ \psi \left( \frac{3+\alpha}{4} \right)-\psi \left( \frac{1+\alpha}{4} \right) \right\}\end{aligned}$$
\(\psi (*)\) is the Digamma Function.
$$\begin{aligned} I(\alpha) &= \frac{1}{4}\int \left\{ \psi \left( \frac{3+\alpha}{4} \right)-\psi \left( \frac{1+\alpha}{4} \right) \right\} d\alpha \\ &= \left(\ln \left( \Gamma \left( \frac{3+\alpha}{4}\right)\right)- \ln \left( \Gamma \left( \frac{1+\alpha}{4}\right)\right)\right)+C \end{aligned}$$
By letting \(\alpha = 0\), we obtain
$$ C= \ln \left( \frac{\Gamma \left( \dfrac{1}{4}\right)}{\Gamma \left( \dfrac{3}{4}\right)}\right)$$
Therefore
$$ \begin{aligned} I(\alpha)&= \ln \left( \frac{\Gamma \left( \dfrac{3+\alpha}{4}\right)}{\Gamma \left( \dfrac{1+\alpha}{4}\right)}\right)+\ln \left( \frac{\Gamma \left( \dfrac{1}{4}\right)}{\Gamma \left( \dfrac{3}{4}\right)}\right) \\ &= \ln \left( \frac{\Gamma \left( \dfrac{3+\alpha}{4}\right) \Gamma \left( \dfrac{1}{4}\right)}{\Gamma \left( \dfrac{1+\alpha}{4}\right) \Gamma \left( \dfrac{3}{4}\right)}\right)\end{aligned} $$
Our integral is a special case when \(\alpha = 2\), therefore
$$ I(2) = \int_0^1 \frac{t^2-1}{(t^2+1)\ln t}dt = $$
$$\ln \left( \frac{\Gamma \left( \dfrac{5}{4}\right) \Gamma \left( \dfrac{1}{4}\right)}{\Gamma \left( \dfrac{3}{4}\right)^2} \right) = {2\ln \left( \frac{2\Gamma \left(\dfrac{5}{4} \right)}{\Gamma \left( \dfrac{3}{4}\right)}\right)}$$
I thought only Physicists were allowed to do that! Of course we rarely check to see if we can...
-Dan
Here's another method to do it without using differentiation under the integral sign.
$$ \begin{aligned} I &= \int_0^1 \frac{t^2-1}{(t^2+1) \ln(t)}dt \\
&= \int_0^1 \frac{t+1}{t^2+1}\frac{t-1}{\ln(t)}dt \\
&= \int_0^1 \frac{t+1}{t^2+1} \int_0^1 t^x dx \ dt \\
&= \int_0^1 \int_0^1 \frac{t^{x+1}+t^x}{t^2+1}dt \ dx \\
&= \int_0^1 \int_0^1 (t^{x+1}+t^x)\sum_{n=0}^{\infty}(-1)^n t^{2k} dt \ dx \\
&= \int_0^1 \left( \frac{1}{x+1}+\frac{1}{x+2}-\frac{1}{x+3}-\frac{1}{x+4}+\cdots \right)dx \\
&=\ln\left(\frac{2}{1} \right)+\ln\left(\frac{3}{2} \right)-\ln\left(\frac{4}{3} \right)-\ln\left(\frac{5}{4} \right)+\cdots \\
&= \ln \left[ \prod_{k=0}^{\infty}\frac{(4k+3)^2}{(4k+1)(4k+5)} \right] \\
&= \ln \left[ \prod_{k=0}^{\infty}\frac{(k+\frac{4}{3})^2}{(k+ \frac{1}{4} )(k+\frac{5}{4})}\right]
\end{aligned}$$
This product can be tackled using the formula
$$ \prod_{k=0}^{\infty} \frac{(k+a_1)(k+a_2)(k+a_3) \cdots (k+a_j)}{(k+b_1)(k+b_2)(k+b_3) \cdots (k+b_j)} = \frac{\Gamma(b_1) \Gamma(b_2) \Gamma(b_3) \cdots \Gamma (b_j)}{\Gamma(a_1) \Gamma(a_2) \Gamma(a_3) \cdots \Gamma (a_j)}$$
where $a_1+a_2+\cdots +a_j = b_1+b_2+\cdots +b_j$ and no $b_j$ is 0 or a negative integer. Applying this gives
$$ I= \ln \left( \dfrac{\Gamma \left( \frac{1}{4}\right)\Gamma \left( \frac{5}{4}\right)}{\Gamma \left( \frac{3}{4}\right)^2}\right)$$
  • · Replies 27 ·
  • · Replies 19 ·
