How Does Kinetic Energy Change at Maximum Height in Projectile Motion?
The discussion centers on the change in kinetic energy of a projectile at its maximum height, specifically when launched at a 60-degree angle. The initial kinetic energy (KE) is denoted as E, with the horizontal component at maximum height calculated as E Cos(60), resulting in a KE of 0.25E. Participants confirm that the horizontal component of velocity remains unchanged during projectile motion, leading to the conclusion that the kinetic energy at maximum height is one-quarter of the initial kinetic energy.
  • Understanding of projectile motion principles
  • Knowledge of kinetic energy formulas
  • Familiarity with trigonometric functions, specifically cosine
  • Basic physics concepts regarding velocity components
  • Study the derivation of kinetic energy formulas in projectile motion
  • Learn about the conservation of energy in physics
  • Explore the effects of different launch angles on projectile motion
  • Investigate the relationship between velocity components and energy in motion
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of energy transformation in projectile motion.
Brianne
kinetic energy stuff...
here's the question...
an object is thrown upwards at a projection angle of 60 degree with kinetic energy E. When the object reaches max height, its kinetic energy becomes
A. (1/8)E
B. (1/4)E
C. (1/2)E
D. (3/2)E
I'm totally no idea...some1 kindly tells me the concept of this question... x_x
When the object is just launched it has E Cos (60) energy in the horizontal direction and E Sine (60) in the vertical direction. When it arrives at the top end of travel (vertically) it only has the horizontal energy left.
Therefore it is E Cos (60) = 0.5 E
You need to know what percentage of the object's initial KE is associated with the horizontal component of its velocity. (The part associated with the vertical component will go to zero at max height.) Hint: If the initial speed is V, what's the horizontal component of the velocity?
i've seen the answer is 0.25E from the book, so I just think should we squaring the cos60, ie (cos60)^2=0.25?
Doc Al: if the horizontal component of velocity remains unchange in a projectile motion, so the velocity is still v isn't it?
Initial Kinetic energy : E = \frac{1}{2}mv^2
K.E at the highest position: \frac{1}{2}m(v cos60)^2
Rest i leave upto you.
BJ
Brilliant question, makes you see _why_ KE _is_ proportional to velocity squared. If you think about KE has to be, then, this question reveals that it must be proportional to velocity squared simply because it is separable in the different spatial directions. WOW it really blows my mind. It is probably neater to say that the velocity in the horizontal direction is half the initial straight line velocity from simple geometry rather than having to appeal to trig (though trig is more general). And then say it this half velocity that you are squaring to get the quarter energy.
Yes, but why? The answer is to compare the initial KE (which comes from both the vertical and horizontal components of the initial velocity) to the final KE (which comes only from the horizontal speed). (See Dr.Brain's post.)
I'm not sure what you mean. If the initial velocity (with magnitude V) has components:
V_{ix} = V \cos \theta
V_{iy} = V \sin \theta
Then at the top of the motion, since the vertical component is zero, the velocity will have components:
V_{fx} = V \cos \theta
V_{fy} = 0
  • · Replies 19 ·
  • · Replies 54 ·
11K
  • · Replies 32 ·
