How does matter know how to move?
  • Thread starter Thread starter PeterDonis
    Matter
[Moderator's Note: This thread was split off from a previous thread because of a change of topic.]
JonathanCollins said:
how can 1 particle of matter influence another particle in a remote location to move towards it with only empty space in between?
It doesn't. Matter influences the curvature of spacetime locally; the curvature of spacetime propagates to distant locations; and the curvature of spacetime at those distant locations tells the matter there how to move. In a static or nearly static situation, the "propagation" part is not easily tested; but there are small effects that show it. One of them is the perihelion precession of the planets; that wouldn't be there if gravity were an "instantaneous" Newtonian force acting through empty space.
Likes vanhees71
But if as you suggest matter influences the curvature of spacetime locally through what mechanism does it achieve this? A billiard ball moves along a flat table as a result of a collision by the cue transferring its momentum to the ball; after it has left the cue it cannot be persuaded to return to the cue without a change of momentum occurring in the opposite direction. If you put the ball inside a straight tube it wouldn't move; if you put the ball inside a curved tube it still wouldn't move. How can space which is essentially void have a shape? What actually causes a particle of matter to move from location A to location B in the vacuum of space within a gravitational field?
The Einstein Field Equation describes how it happens. I don't know what exactly you would consider a "mechanism", but apparently you mean something like "anything that looks like a mechanism I would see in everyday life" (see below). That's not a good heuristic.
Is this what you mean by a "mechanism"? Do you understand how much complexity underlies this process?
So what?
You mean, it wouldn't move if no other interactions were present and the tube were horizontal (or floating in free space, far from all other objects). Again, so what?
GR doesn't say gravity is a manifestation of space curvature; it says it's a manifestation of spacetime curvature. More precisely, tidal gravity is a manifestation of spacetime curvature; in fact it is spacetime curvature. So if the term "spacetime curvature" bothers you, just substitute "tidal gravity". You'll preserve all the correct predictions of GR.
The same thing that causes it to move from location to location in the vacuum of space without a gravitational field. Freely falling objects are the default state, so to speak: they just "move through spacetime" following whatever the natural pathway is in their local region.
Peter is correct. But you seem to searching for an answer to a very deep question! Your question is basically: How does action at a distance work? The truthful answer (all virtual particles aside) is: we don't know - it just does.
Edit: yet ;)
What is the mechanism by which the cue transfers momentum to the ball?
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
