Averagesupernova
- 1,454
If you actually did something besides pick stuff from the net that you really don't know what the signal is you would understand this. If you concern yourself with peak without considering RMS in this you will not get very far. Yes, adding a second signal from a different string could reduce the peak of the signal while increasing the RMS voltage.Xenon02 said:I just wondered if the chord could just make the E1 reduced from 0.8V to smaller like 0.6V
You need to study up on signals and systems to fully understand this. It's apparent that you don't. Yet you think you do.
If the above can be believed as accurate then the fact the RMS is higher with the chord vs E2 and the peak remained unchanged (20 mV to 36 mV RMS and 300 to 300 peak) should have answered your question, yet you asked. So that implies you don't trust the source of this info.
It's really difficult to get anything meaningful about the behavior of the pickup just thumbing it. A constant vibration of the string(s) will tell you something. This has to be controlled and the travel of the string measured. This takes patience and a well fixtured setup.
