How Does Qubit Orientation on the Bloch Sphere Indicate Quantum States?
The Bloch Sphere representation of qubits illustrates that any vector on the sphere corresponds to a superposition of the basic states |0> and |1>. A vector at z=0 indicates an equal superposition of both states, represented mathematically as $$\frac{1}{\sqrt{2}} \left[ |0 \rangle + e^{i \phi} | 1 \rangle \right]$$. When the vector points 45 degrees above the equator, it can be expressed using the equation $$\cos \left( \frac{\theta}{2} \right) |0 \rangle + \sin \left( \frac{\theta}{2} \right) e^{i \phi} | 1 \rangle$$, where $$\theta = 135^\circ$$ results in a superposition favoring |1>. If a qubit is unaffected by external noise, it will not remain static unless both states have the same energy, which is rarely the case, leading to precession.
  • Understanding of quantum mechanics concepts, specifically qubits
  • Familiarity with the Bloch Sphere representation
  • Knowledge of superposition and quantum state notation
  • Basic grasp of mathematical expressions involving trigonometric functions and complex numbers
  • Study the mathematical foundations of the Bloch Sphere representation
  • Learn about quantum state superposition and entanglement
  • Explore the effects of external noise on qubit states
  • Investigate the implications of energy differences on qubit precession
Quantum physicists, quantum computing researchers, and students studying quantum mechanics who seek to deepen their understanding of qubit behavior and representation.
*FaerieLight*
There is something that I don't quite understand in relation to the Bloch Sphere representation of qubits. I've read that any vector on the sphere is a superposition of two basic states, like spin up and spin down, denoted by |1> and |0>.
So does this mean that if the vector is at z=0 (pointing towards the equator), then it has neither spin-up nor spin-down components?
If the vector is pointing up 45 degrees above the equator towards |1>, then how is this represented by equations as a superposition of |1> and |0> ?
Also, if a qubit is not affected by external noise, then does it remain a static unprecessing vector on the Bloch Sphere?
No, it means that it is an equal superposition of spin-up and spin down,
The general equation is
so ##\theta = 135^\circ = 3\pi/4## results in
\frac{\sqrt{2 - \sqrt{2}}}{2} |0 \rangle + \frac{\sqrt{2 + \sqrt{2}}}{2} e^{i \phi} | 1 \rangle
so a superposition that is more ##|1 \rangle## than ##|0 \rangle##.
Only if the two states have the same energy. This is not true in most cases, so one will see a precession as the angle ##\phi## will be time-dependent.
