How does rainwater compare to home water in terms of potential harm?
  • Context: High School
  • Thread starter Thread starter Phys12
    Rain Water
The discussion revolves around the potential health risks associated with rainwater compared to home water supplies. Participants explore the cleanliness of rainwater, its interaction with atmospheric contaminants, and the implications for health and hygiene. The conversation touches on various aspects including environmental factors, historical beliefs about illness, and the treatment of drinking water.
  • Some participants suggest that rainwater can pick up contaminants from the atmosphere, which may vary depending on local pollution levels.
  • Others argue that touching rainwater is unlikely to cause illness, emphasizing that the real concern is with drinking contaminated water.
  • One participant mentions that the logic connecting being wet to illness involves body temperature loss and immune response, rather than direct effects of rainwater.
  • There are claims that home water supplies are treated and filtered, making them safer than rainwater, although some point out that filtration may not eliminate all biological contaminants.
  • Some participants question the validity of anecdotal claims about rainwater causing illness, suggesting that historical beliefs may not be supported by current understanding.
  • A later reply raises the question of whether bacteria in clouds could negatively affect rainwater quality.
  • There is a discussion about the equivalence of rainwater to distilled water under certain conditions, though it is noted that mineral content differs significantly from municipal water sources.
Participants express multiple competing views regarding the safety of rainwater versus home water. There is no consensus on the health implications of rainwater exposure, and the discussion remains unresolved on several points.
Participants highlight the dependence of rainwater cleanliness on environmental conditions and the limitations of home water treatment methods. The discussion also reflects varying interpretations of historical beliefs about illness and hygiene.
Phys12
I've heard people say that if you come back from the rain and you're soaking wet (because of the rain water), you should take a bath to prevent any kind of illness.
However, how can it be that rainwater can cause you harm, but the water in your home cannot? Or maybe, how does your home water prevent the illness that you might've gotten from the rainwater?
Thanks!
Thanks!
"I've heard people say" is not a valid way to start a thread in the technical PF forums. Can you please point to a mainstream reference that makes this assertion?
Well, when rain falls, it has to pass through the atmosphere which can contain a variety of contaminants. The water can pick up these chemicals and unclean things. The cleanliness of rain water really depends on your environment (e.g. is the air around your area particularly polluted, etc.). In polluted areas, there would be a good amount of contaminants like sulfur dioxide. But it only makes sense to consider this for drinking water.
You're most likely never going to get sick from touching rain water. I never heard that before. Anyway, if the water was so horribly bad that you have to take a shower or something, you shouldn't even live in such a region to start with.
The water that comes from our faucets is obviously different! Before it gets to your house, it's cleaned and filtered. And, depending on the type of home you have, that entire system might possibly be within your property (i.e. if a well supplies your water source).
The logic goes as follows:
wet ⇒ loss of body temperature by evaporation ⇒ being cold ⇒ reduced capability of immune system ⇒ more difficulty to fight viruses.
Temperature or wetness alone does not have any effect. You need to catch a virus, too.
In many places it's not really different because it is ONLY filtered and that just takes out macro level gunk, not bio-organisms. In many places spring water (which is almost directly rain water) is considered better than water drawn from an aquifer by a well.
Well, it was just some of my friends talking and I wondered whether they were right or not.
:D All right, thanks a ton for your help!
Yes, you are right.
By the way, I wonder if the bacteria that lives in clouds would affect rain water in negative way?
Yes, we understand that. The point is, that's not a good reference for this forum. I understand that you were just looking for some informed opinion on what your friends said, but the point is that this forum is not here to debunk random nonsense spouted by random people out in the world. If you had done some research on your own and did not find a satisfactory answer, then you would at least have some valid (presumably) citations from which to springboard your question.
Will keep that in mind for my future posts, thanks.
Good. I also understand, by the way, that this forum's rules can seem a bit unfriendly but they are not meant to be, they are just meant to keep the focus on established science.
While not technically correct, rain water collected in a clean barrel, as well as that which directly lands on you for that matter, is not too far removed from being equivalent to distilled water. Certainly, it will contain some particulates from nucleation (formation of the rain drop) as well as traveling through the atmosphere but this will in no way bring the mineral content of the rain water anywhere near equivalent to ground water or municipal water sources.
I believe the tale to wash up after being out in the rain has more to do with hygiene related ideas accumulated over the history of human-kind, that it was noticed somewhere people in prior times were more likely to become ill after being in the rain. However, we've recently noticed that there really isn't a cause-effect correlation between illness and rain exposure and more likely the tendency to become ill is due to the body's temperature lowering as a result of evaporation making it more susceptible to some pathogens it likely already had been exposed to.With regards to the issue of forum etiquette, I don't see this as much different than something like "my boss and I were arguing about some MIL-SPEC" application to our product. What are your thoughts?" type of topics that pop up now and then. Besides, now you are going to take the words of strangers and present those to your friends.
Excellent points.
Not clear what your intent is with this statement. Are you being supportive of the forum etiquette or dismissive of it?
I'm only saying I've seen threads / topics started in a similar manner without any comment by others. Also, a quick perusal of the TOC doesn't suggest this is not acceptable; I could be wrong, though.
Had it been unacceptable, berkeman would have closed the thread. He and I are just saying that it's not appropriate, which is different from unacceptable, and yes, I've also seen threads started in similar manners before without comment but that doesn't make them a good idea.
We like for folks to do some research on their own before asking questions here. That helps them to get better at answering their own questions (an important skill in life), and helps others to respond better to the posted question. In this case, the OP could have used a Google search to get some initial information, and then could have posted links to their reading with questions about whether the claims made sense.
In general, threads that start with just "I heard that" don't go very well. OTOH, "I read that _______ at this link _______, and haven't been able to find much more info about it" would be a better thread starter... :smile:
This thread has been very heavy in its way of dealing with a perfectly valid but, perhaps not expertly put, post.
It is and always has been what we call a "popular misconception" and anyone who has had a Mum tell them to come indoors this minute because it's raining can sympathise with bringing the subject up on a reputable Physics Forum. Doesn't PF ever try to debunk wrong theories? The theory no longer applied to well heeled western town dwellers and 'explorers'.
In these days of microfibre and breathable clothes and central heating, the main risk is no longer as relevant as it was in the 'olden days'. There was a (well documented) time when, if you got your clothes wet, you would be cold, due to evaporation for many hours / days even (approaching hypothermia) and been subject to real infections as your body resistance to infections was lowered. That would have happened with rain or pure distilled water. Having a (warm) bath and putting on dry clothes would reverse the process. Rich people would have had access to this treatment whereas their servants and tenants would have had to 'just get on with it' and their life expectancy would have been accordingly shorter.
PS. I watched Leonardo DiCaprio in 'the Revenant' last night. How was he supposed to have avoided hypothermia? I should like to know. His clothes were ringing wet most of the time and the rivers were full of melted snow. Good film tho'.
Not usually -- we prefer to just post links to other locations on the web with the debunking info, and close the PF thread. Like we do all the time with PMM discussions.
This discussion isn't too bad, though. I just wish the OP had put a bit more effort in before asking the question. :smile:
I can understand that, as a general principle but I wish people wouldn't just post a link, with no personal input. Bare links are frequently posted as a result of a quick search and they are not always very relevant or even read by the 'helpful' respondent. I do appreciate that people are always posting with 'bad' ideas and from positions of gross ignorance (Present OP not included, btw). There can be sloppy phraseology, text speak and all the rest. That sort of thing doesn't generate initial good will from members, I know but we could be more generous in the first instance. I do not refer to the arrogant 'but surely' attitudes that we find from questioners who don't like PF's answers; they deserve all they get from grouchy members.
But, when one is 'outside the tent', it is often very hard to find a way in. Not everyone instinctively uses Google for technical matters - even if they do all their shopping online and it can be hard to generate fruitful search criteria when the whole subject is a blur. There are ways of helping in that direction.
This thread has been an example where the visitor hasn't been treated in a very friendly way. The original point was well worth making and has benefitted from a number of useful inputs - to the extent of identifying some good explanations and discarding poor ones. That's what discussions are all about, even when they're at a lowly Science level. But the useful content has been clouded with some unwarranted criticism of the poor OP. I worry that he /she is not likely to come back, which is a shame.
I don't think that the members were that harsh. I do think that we got a little off topic, but I felt that the correction was necessary for future posts. Also, I'll absolutely come back! This place has been of enormous help to me these past months and will likely continue to be throughout my college life and beyond. :smile:
Glad you have a relatively thick skin! You need to be able to resist taking offence when people get aerated about topics in Physics. (We all have to deal with total idiots who have no idea what we're talking about. :wink:)
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 23 ·
  • · Replies 20 ·
  • · Replies 26 ·
