How Does Soap Film Thickness Affect Color Reflection in Optics?
The discussion focuses on how the thickness of a soap film affects the colors observed when white light reflects off it. As the soap film forms on a horizontal cylinder, its thickness varies, influencing the color spectrum seen. Thicker areas of the film may appear darker or even black due to destructive interference, while thinner areas reflect more vibrant colors. Participants express confusion about the relationship between film thickness and color reflection, particularly regarding the transition from vibrant hues to darker shades. Understanding this relationship is key to grasping the optical properties of soap films.
4.19mile
Soap Bubbles in terms of optics etc. Help needed :)
The opening of a metal cylinder is dipped in soapy water so that a soap film forms. The cylinder is then turned so it is horizontal (and the soap film is vertical). What happens to the thickness of the soap film?
White light is shined through the cylinder, and you view the light that reflects off of the film. What do you see?
How is the thickness of the soap film related to what you see reflected off of the film?
Well this is more of a conceptual one.
I'm a bit confused at this one. For the second one, do you see a spectrum of colors (the rainbow)? I'm not sure about the thickness of the soap etc. If the soap is at its thickest it becomes black.. does it progressively become darker? Not sure again.
Thanks to anyone who can help me on this!
Any help on this?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
