How does the Earth produces it's own magnetic field?
The discussion revolves around the mechanisms by which the Earth produces its magnetic field, specifically focusing on the concept of the geomagnetic dynamo and the role of convection currents in the Earth's outer core. Participants explore theoretical aspects and inquire about experimental demonstrations.
  • Some participants assert that the convection of the inner core, assumed to be liquid metal, produces the Earth's magnetic field through a process known as the geomagnetic dynamo.
  • There is a question regarding whether this phenomenon can be replicated in a small laboratory setting.
  • One participant explains that convection currents in the molten metal, driven by differences in temperature, pressure, and composition, generate electric currents that produce magnetic fields, creating a self-sustaining loop.
  • Another participant points out the need for proper citation when quoting published material, highlighting a potential issue of plagiarism in the discussion.
  • A participant acknowledges the oversight in providing a citation due to time constraints.
Participants generally agree on the existence of the geomagnetic dynamo as a mechanism for the Earth's magnetic field, but there is uncertainty regarding the feasibility of replicating this process in a laboratory. The discussion also includes a disagreement about proper citation practices.
Some statements rely on assumptions about the state of the Earth's inner core and the nature of convection currents, which may not be universally accepted. The discussion does not resolve the complexities of replicating the geodynamo in a controlled environment.
dan020350
I read an articles that the convection of the inner core of the Earth which is assume to be liquid metal produces Earth's magnetic field, is this true? Has scientists did a demo?
No. The Earth is quite large.
Differences in temperature, pressure and composition within the outer core cause convection currents in the molten metal as cool, dense matter sinks whilst warm, less dense matter rises. The Coriolis force, resulting from the Earth’s spin, also causes swirling whirlpools.
This flow of liquid iron generates electric currents, which in turn produce magnetic fields. Charged metals passing through these fields go on to create electric currents of their own, and so the cycle continues. This self-sustaining loop is known as the geodynamo.
@Neon, when you quote published material, as you have done above, you need to provide a citation, a reference to where you found the material. In some contexts you would be considered guilty of plagiarism.
I found what you copied here: http://www.physics.org/article-questions.asp?id=64, in the 5th and 6th paragraphs.
Mark i did just didnt have time to put the reference as my battery was 1 % and i just posted it. Afterwards i for got about it.Sorry
  • · Replies 42 ·
  • · Replies 22 ·
  • · Replies 17 ·
