How Does the Power Set Size Double with Each Additional Element?
Samuelb88
Let [n] denote the set consisting of the first n natural numbers 1, 2, 3, ..., n. Use induction to prove that the power set P([n]) has exactly 2^n elements.
1) Base case: P([1]) = {{1}, null}. 2^1 = 2 elements.
2) Inductive step: Assume P([n]) has 2^n elements and prove P([n+1]) has 2^(n+1) elements.
I am stuck on the inductive step. I am not sure how to prove P([n+1]) has twice as many elements as P([n]). Through numerical experimentation for some small values of n, I've found that the number of new subset elements for each value of n is can be "represented" by pascal's triangle so I tried expressing the numbers of elements for P([n]) as a sum of the binomial coefficients:
2^n = \sum_{j=1}^{n} \frac{n(n-1)...(n-j+1)}{j!}\right)
And by multiplying both sides by 2 would yield 2^(n+1) on the LHS, however, I can't seem to equate the RHS to:
\sum_{j=1}^{n+1} \frac{(n+1)(n)(n-1)...(n-j+2)}{j!}\right)
Am I on the right track? Does this idea work? Any hints would be great! :)
You are making this too complicated. P(n) is all of the subsets of {1,...,n}. P(n+1) is all of the subsets of {1,...,n,n+1}. For every subset in P(n) you can make 2 subsets of P(n+1) by either including the element n+1 or not.
Right, that makes sense. But how can I apply that idea to my inductive step?
Ok, then the number of elements in P(n+1) is twice the number of elements in P(n), isn't it?
Correct. But that seems like I am merely "conjecturing" that P(n+1) has twice as many elements as P(n), not proving.
PS: Sorry, I made a typo in my original post. It use to read, "...assume P([n+1])..."
No, you are not "conjecturing" anything. Every set in P(n+1) either contains n+1 or it doesn't. If it doesn't contain n+1 then it is in P(n). How many such sets are there?
If it does contain n+ 1 then it is a union, \{n+1\}\cup A where A does NOT include n+1. How many such sets are there?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
