I How Does the Supremum of -A Relate to Its Elements?
  • I
  • Thread starter Thread starter Mr Davis 97
Mr Davis 97
Given that ##A## is a nonempty set of real numbers, and that ##-A = \{-x ~ | ~ x \in A\}##, I want to show the following:
##\forall a' \in -A, ~ \sup (-A) \ge a'## implies that ##\forall a \in A, ~\sup (-A) \ge -a##.
This is intuitively obvious, as we just "replace" ##a'## with ##-a##. But I don't see how to make the switch from one to the other rigorously.
Per definition we have ##\forall a \in A \,\exists \, a' \in -A \, : \, a'=-a \,\Longrightarrow \, \forall a \in A \,\exists \, a' \in -A \, : \, \operatorname{sup}(-A)\stackrel{given \, cond.}{\geq} a' = -a##
But I don't think this would be more helpful than a simple "thus".
This is a case where the abbreviations we use obscure the meaning and make things more difficult.
The symbol string
$$\forall x\in S, (P(x))$$
is actually shorthand for
$$\forall x(x\in S\to P(x))$$
So
$$\forall a' \in -A, \sup (-A) \ge a'$$
means
$$\forall a'(a' \in -A \to \sup (-A) \ge a')$$
which, by the definition ##-A\equiv\{x\ :\ -x\in A\}##, means
$$\forall a'(-a' \in A \to \sup (-A) \ge a')$$
We then write down an instance of the Axiom Schema of Substitution in which we substitute ##-a## for ##a'## in the consequent, to give us:
(\forall a'(-a' \in A \to \sup (-A) \ge a'))
\to
(-(-a) \in A \to \sup (-A) \ge (-a))
Using Modus Ponens on this and the previous line, and replacing ##-(-a)## by ##a## we get
$$a \in A \to \sup (-A) \ge -a$$
We then universally quantify ##a##, which we can do because it is a free variable in the formula, under the Axiom Schema of Restricted Generalisation. This gives
$$\forall a(a \in A \to \sup (-A) \ge -a)$$
which is what we sought to prove.
As usual, when we have to resort to formal logic, proofs get rather longer!
Likes Mr Davis 97
The symbol string
So
means
\to
Since for my purposes that is a tinge too formal, how would you suppose that I write out such a step in a proof (where the proof involves showing that ##\inf A = - \sup (-A)##)? It it enough to just say that ##\forall a' \in -A, ~ \sup (-A) \ge a'## implies that ##\forall a \in A, ~\sup (-A) \ge -a##?
Yes, I think it is sufficient. I first had to write it down to "see" whether the signs are not confused, and came up with the explanation:
##\forall a' \in -A, ~ \operatorname{sup}(-A) \geq a'## is shorthanded ##\operatorname{sup}(-A) \geq -A## and then it is obvious that both inequalities express the same fact.
You can express the proof in simple steps. Suppose a ∈ A. Then -a ∈ -A. So sup( -A ) ≥ -a.
