How does thermionic emission work?
Thermionic emission occurs when the thermal energy of electrons exceeds the work function of a material, typically at temperatures above 1000K. The discussion highlights calculations involving tungsten's work function of 4.5 eV and the discrepancies encountered when applying Wien's Law and the Richardson-Dushman equation. It is clarified that thermionic cathodes often use materials other than tungsten and operate at temperatures below 600°C. The conversation emphasizes the importance of understanding the relationship between temperature, work function, and electron emission dynamics.
  • Understanding of thermionic emission principles
  • Familiarity with Wien's Law and its applications
  • Knowledge of the Richardson-Dushman equation
  • Basic concepts of electron work function in materials
  • Research the Richardson-Dushman equation and its implications for thermionic emission
  • Explore the properties and applications of various thermionic cathode materials
  • Study the effects of temperature on electron emission and work function
  • Learn about the role of electric fields in electron emission dynamics
Physicists, electrical engineers, and materials scientists interested in thermionic emission and its applications in electron gun technology.
Helloworld75344
I’ve been curious about understanding the mechanism behind themionic emission from what I have read I found that themionic emission happen when the energy from added temperature excess the work function of the material. I also readed when temperature excesses 1000k themionic emission happens but when I calculate the energy in Ev from that temperature I get a number no where close to the work function of tungsten a material commonly used as filament for electron guns so what gives?
Wien Law
~~~~~~~~~~~2.89e-3
Wavelength =————-
~~~~~~~~~~~~1000k
Wavelength = 289e-8m
Conversation of wavelength to Joules
~~(6.626e-27)(3e10)
E=—————————
~~~~~~289e-8m
E=0.06878e-18
Joules to Electron volts
E = 0.06878e-18 * 6.242e18
E = 0.4293ev
Tungsten Workfunction = 4.5ev
I not sure if I’m just calculating the temperature with the wrong equation but those numbers don’t seem anywhere closes , when I used the work function of tungsten to calculate the temperature I get a number that is insanely high
Ev to wavelength
~~~~~~~~~~~(6.626e-34)(3e10)
Wavelength= —————————-
~~~~~~~~~~~~(4.5ev)/(6.242e18)
Wavelength = 2.757e-7
Wavelength = 275.7nm
Wien law
~~~~~~2.89e-3
T(k) = ————
~~~~~~2.757e-7
T(k) = 10482.408k
10482 KELVIN! that way excess the melting temperature of tungsten and that far exceeds the temperature in any electron gun if I am calculating the temperature wrong how do I do it properly and can anyone confirm that thermionic emission happens from temperature exceeding work function?
I read that thermionic emission happens from exceeding the work function of material from it Wikipedia page(I know it’s not the most credible site)
I also read that the temperature for thermionic emission of t > 1000k from Wikipedia also.
Sorry for any grammar mistakes I’m not a very good at spotting them
In the Wien's law calculation for the peak wavelength of the Planck blackbody emission spectrum, ## 4.96=\frac{E_{\lambda \, max}}{k_B T} ##, so that ## E_{\lambda \, max}=4.96 \, k_B T ## gets you a better number than if you just use ## k_B T ##, which is ## 1.38 \cdot 10^{-20}/1.602 \cdot 10^{-19} =.086 \, eV ## for ## T=1000 ##, and compare it to the work function ## W ##. Part of the answer would seem to be in the ## T^2 ## factor in the Richardson-Dushman equation. See http://simion.com/definition/richardson_dushman.html
Thermionic cathodes do not use Tungsten as a source of electrons. They are coated with a range of materials. See this wiki link about hot cathodes. The operating temperature of many valve cathodes is less than 600°C (also mentioned in the link).
Edit: What have you read up about thermionic emission? Electrons do not totally escape from a hot cathode if there is no handy positive electrode nearby. Without an external field, they hang around the surface and return to the cathode which has become positively charged. Electrons do not need 'escape velocity'.
