How Far is the Boat From its Original Position?
The discussion centers on calculating the distance a boat is from its original position after traveling upstream for 3.5 hours and downstream for 2.5 hours, given specific speeds for the current and the boat in still water. The final equation indicates that the boat is 12.5 km downstream from the start. However, there is confusion regarding the time the boat spent upstream, with some participants questioning the claim that it only traveled upstream for 1 hour. The importance of using different frames of reference is emphasized, as the speeds provided relate to different contexts: the boat's speed in still water versus the current's speed relative to the ground. The conversation highlights the need for clarity in problem-solving approaches and the interpretation of given data.
Benjamin_harsh
How far from its original position is the boat now?
With reference to ground, the water travels downstream for 2.5+3.5= 6 hours.
With reference to water, the boat went upstream for 1 hour. So the boat is
10/3×6−15/2×1=12.5 km downstream from the start.
A boat goes upstream for 3 hr 30 min and then goes downstream for 2 hr 30 min. If the speed of the current and the speed of the boat in still water are 10/3 kmph and 15/2 kmph respectively, how far from its original position is the boat now?
Final Equation: 10/3×6−15/2×1=12.5 km downstream from the start.
Why should we solve this question through references?
How boat went upstream for 1 hour if question clearly says boat goes upstream for 3 hr 30 min?
You seem to have stated the problem twice with different values. What is the actual statement of the problem, as stated wherever you got it from?
  • Skeptical
Likes berkeman
Because the boat is moving through the water, which is itself moving. If the boat's speed was only 10/3 km/hr, and it was traveling upstream, it would stay in the same place, relative to the ground, but would have traveled 10/3 km in an hour, relative to the water.
What references are you referring to?
Frames of Reference?
Moving on, in an effort to see how you attempted to solve this problem:
The information in your original post appears to be rather scrambled. I did manage to pick out the actual problem.
A boat goes upstream for 3 hr 30 min and then goes downstream for 2 hr 30 min. If the speed of the current and the speed of the boat in still water are 10/3 kmph and 15/2 kmph respectively, how far from its original position is the boat now?​
Then fast forward to what you call the
Final Equation: 10/3×6−15/2×1=12.5 km downstream from the start.​
I agree that this is the correct answer numerically, but does this solution make sense?
Let's see. 10/3 (km/h) is the speed of the water. That's downstream and with respect to (w.r.t) dry land.
Also, 15/2 (km/h) is the speed of the boat in still water. I.e. The boat travels at a speed of 15/2 (km/h) w.r.t. the water.
Digging through the OP, we find your explanation of where the 6 and the 1 come from and that both are in units of hours.
With reference to ground, the water travels downstream for 2.5+3.5= 6 hours.​
With reference to water, the boat went upstream for 1 hour.​
(By the way: I notice that your solution does use references.)
Multiplying 10/3 km/h by 6 h makes sense and could possibly be useful in solving this problem.
But, what do you mean by "the boat went upstream for 1 hour"? You then multiply this by the speed of the boat w.r.t. the water, which you subtract from the distance the water moved in the entire 6 hours.
The boat goes upstream for 3.5, not just 1 hour, then goes downstream for another 2.5 hours.
You have the boat going upstream for just 1 hour, then what? What does it do the other 5 hours?
You haven't fully explained your reasoning here.
Likes jim mcnamara
How boat went upstream for 1 hour only if question clearly says boat goes upstream for 3 hr 30 min?
My doubt regarding the way of approach to answer.
"A boat goes upstream for 3 hr 30 min and then goes downstream for 2 hr 30 min". 3.5hr - 2.5hr = 1hr
Likes Merlin3189
So, that solution to the problem in the Original Post is not your solution? I misunderstood that.
Was that solution given to you written out in the manner you posted ? It does seem to me that the approach is somewhat unusual.
Can you show me another simple approach ?
Yes, we can get you started on another approach. But first ...
As to the question asked:
It is absolutely necessary due to the information given in the problem itself. The two given speeds are in reference to different objects: the land for the water, the water for the boat. Right?
Now for an alternate approach:
What is the boat's speed relative to land on the upstream portion of the trip?
What is the boat's speed relative to land on the downstream portion of the trip?
