How far will you slide if you fall off a skateboard?
The discussion revolves around understanding the physics of sliding and friction, particularly in the context of skateboarding. A user expresses difficulty in solving a problem without specific numbers and requests random numbers for demonstration. A response suggests conducting a practical experiment by skateboarding to gather data, emphasizing the importance of real-world observations over assumptions. Key factors affecting sliding distance include the surface friction, the position of the body during a fall, and the initial speed. The responder shares a personal anecdote about a past skateboarding accident, illustrating how variables like weight, speed, and surface conditions influence the outcome of a fall. The conversation highlights the relationship between friction, momentum, and stopping distance, noting that stopping distance is inversely proportional to friction and proportional to the square of initial velocity.
ebola_virus
the question is the topic, but I am sorri i don't have any numbers i can deal with, because we're just supposed to demonstrate that we understand how we solve htese porblems. unfortunately, I don't. could anyone just give me random numbers and tell me how to olve this question? thanks. I am gussing it involves frictiona dn all... any suggestions?
Easy this one...
Scientists do experiments don't they? Borrow a skateboard and protective gear, and go skateboarding. Take a tape measure and get some data. This is a FAR better method than making many, many assumptions and then trying to calculate something.
Then analyse your data and make some conclusions.
i know this is an old post, but just remember about the surface of the ground you are sliding on, combined with the part of you or your pads you are sliding on. This is a variable of friction and your momentum. Also, your center of mass upon the fall (beginning of the slide) will help govern your rate of decceleration. If you are on your knees at the beginning of the fall, you will slide farther, if you are on your feet at the beginning of the fall and your body slams downward, your slide will be shorter and therefore exert more impact force (upward) on your body. Hopefully, you will not slide at all and instead conserve your potential sliding energy by putting in some work (combined with cat like reflexes) and roll your body to a hault, injury free.
The furthest I ever slid after falling off a skateboard was about eight feet in shorts on rough asphalt scattered with pebbles and a little bit of broken glass when I was 12 years old.
The result was a chewed up nasty right thigh (about 1 foot long and 5 inche wide road rash) that remained there for about 6 months.
I was traveling down a 23° (approximate) downgrade at probably 20 mph.
At the time I weighed no more than 98 pounds.
The high friction of the ground was counteracted by my light weight, high rate of speed, narrow angle of approach (I hit a rock and was thrown forward a good 5 or 6 feet before making contact) and the relatively low friction of my bare thigh.
interesting to think about how your fall might have had worse consequences if you were actually going 10 mph instead of 20mph due to the increased ratio of your speed=directional momentum(forward) vs. gravitationally induced road impact potential energy...
Delta x = v_o t - 1/2at^2
a = coefficient of sliding friction times g
Total stopping distance is inversely proportional to the coefficient of friction, and proportional to the square of the initial velocity. Ask adrian, he checks this occasionally. I was thinking of putting an odometer on my face shield. Boy.. friction is hot ain't it?
Cheers,
Mike
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
