How fast does a blastwave travel?
236 replies · 24K views · last reply
Thank you for the references, I think I have my answer.
Anderson, being an aerodynamicist, only focuses on the shock wave's interaction with the supersonic body, and I was unable to find any reference to its speed of propagation in his book.
I was unable to source a copy of Punty.
But Kinney And Graham provides the answer in Table XI, from which I have graphed the data.
Line graph titled Table XI Kinney & Graham, showing Z (m) from 0 to 500 against T (ms) from 0 to about 1400, with a straight rising curve and a callout reading 343 metres in 1.0 seconds at the 1000 ms mark.
After 1000 milliseconds the shock wave travelled 343 metres. That's Mach 1.0 at NTP.
No. That is the blast wave from a reference explosion: 1 kg, TNT.
The shock wave is very limited in that case. It certainly does not travel 300 metres.
Kinney and Graham appear to use "blast wave" and "shock front" interchangeably.
From p. 1
"The material presented here on explosive blast and shock gives essential background concerning the physics of the blast wave. It describes in relatively simple manner generation of a blast wave with its shock front, its transmission through the atmosphere, its interaction with a variety of structures and objects, and typical structure responses. Preliminary to this study of explosions is a description of explosive blast and shock in the atmosphere."
Do you have an alterrnative interpretation?
Look at the table XI. Column 5 is velocity; m/s.
The velocity, out to the first millisec is falling rapidly;
13500, 8730, 6920, 5870, 5150, 4610, 4180, 3830, 3530, 3280, 3060,
2870, 2700, 2540, 2410, 2280, 2170, 2070, 2067, 1980.
All those shockwave velocities are greater than mach 1.
At 7 us, v=13500, = mach 39.0
At 1 ms, v=1980, = mach 5.8
It falls to M1 = 343 m/s at 400 metres.
Because of the log scale, your average over 1 second, will downplay the initial high temperature and velocity shockwave.
Your extract only looks at the first 0.46 millisecs, less than half a millisecond.
Although I didn't make it clear, my question about the speed of the shockwave related to human scales: I'm talking handfuls of seconds, not sub-millisecs, and assumed that would be the viewpoint of the man-in-the-street when they read about the speed of shockwaves.
But now that I understand that your interpretation includes the examination of the first 1/2 millisecond of the explosion, then yes, it could be said that shockwaves travel faster than the speed of sound.
I prefer my view that at any survivable distance from an explosion, the blast wave, shock front or shockwave will travel from the site of the explosion to your position at Mach 1.
Drakkith said:
The shockwave will lose speed as it travels, eventually turning into a normal sound wave that moves at the speed of sound. I don't know how quickly the shock wave in the video loses speed though.
I think the time in which a shockwave's speed decays to the speed of sound is demonstrated in the Kinney & Graham extract above. It's pretty short!
hmmm27 said:
It stops being called a "shockwave" when the wavefront goes subsonic (relative to local atmosphere).
I think you'll find from the Kinney & Graham reference above, that the wavefront never goes subsonic. After the initial few millisecs, the blast wave, shock front or shockwave proceeds at the speed of sound.
There appears to be two types of shockwaves that I've seen discussed. The first, generated by something traveling supersonic (like a bullet or supersonic aircraft) travels at the speed of sound. The second, generated by rapid expansion, such as in explosions, travels faster than sound (at least initially). Unfortunately both of these appear to share the same name, leading to confusion.
Thanks for the graph and excerpt. "Going subsonic" (my post(s)) was a temporary brainfart, now cleaned up somewhat : apologies for any confusion caused.
They aren't, neither do they appear to ; reread the snippet you quoted.
Everyone prefers their own view.
Your private definition of "shock front or shockwave" is causing a problem in this physics thread.
A shock front always travels at a speed greater than the speed of sound. That is, by definition, because compressive heating of the air, accelerates the back of the shock, to catch up with the front of the shock.
It is the momentum of the sub-sonic blast "wind" that follows, that does most of the physical damage. Survivability comes down to your landing, after being thrown 10 metres in the air, and pelted with a hailstorm of broken glass and bricks.
Yes, there is indeed confusion.
Following Kinney and Graham, we should probably refer to the explosion phenomenon as a "blast wave" having a "shock front" and leave the shock wave (or shockwave) to describe the phenomenon experienced from a supersonic plane or bullet.
Kinney et. al. do muddy the water slightly with the use of "shock wave" on p.55 when discussing the thickness of the shock front and on p. 57 when discussing explosive overpressure, otherwise they refer to "shocks", "shock fronts" and "blast waves".
I remain curious as to the nature of the two "shock waves" referenced by the Slo Mo Guys in my OP,
as well as the nature of the white dome and the silver disk observed in the Beirut explosion videos.
Squizzie said:
I remain curious as to the nature of ..... the white dome and the silver disk observed in the Beirut explosion videos.
The white dome, that follows the blast wave, has a pressure lower than normal atmospheric pressure. The momentary white cloud forms in the partial vacuum, pulled by the outward momentum of the explosion.
The expanding silver disk, marks the progress of the shock front, as it blows the tops off, small waves on the water. In video of atom bomb tests, it can be seen approaching the camera, arriving just before the momentum of the blast wave.
I guess you are referring to the low pressure described in Kinney:
Two pressure curves from a textbook on blast waves: top, pressure against distance at successive times (1) to (4) after an explosion; bottom, pressure against time for an explosive blast wave showing overpressure above atmospheric pressure and a later negative phase below it.
When a gas expands adiabatically, its temperature drops, and in the case of the Beirut explosion, the temperature dropped below the dew point.
I was not referring to Kinney.
I was referring to the partial vacuum that follows, immediately after an explosion.
Apologies, I thought we were on the same page. Which partial vacuum follows?
I don't see any reference to that in Kinney. Do you have a reference please?
Look it up in Kinney.
Sorry you've lost me. I can find no reference in Kinney to partial vacuum.
There is a reference to a reversed blast wind:
"These blast wave effects then decrease quasi-exponentially with time until the pressure reaches atmospheric (zero overpressure) after which there is a slight negative phase, as at point C, along with a reversed blast wind."
along with these two diagrams :
Four line drawings of a single-storey house showing blast wave damage: A before the blast, B just after the shock front passes, C in the negative overpressure phase with reversed blast wind, D after the blast wave subsides. Captioned Figure 1-1.
Line graph of blast wave pressure against time: a sharp rise to a peak, a decay through atmospheric pressure (dashed line) into a slight negative phase, then recovery. Points A, B, C and D are marked on the time axis.
to which I referred in my earlier post.
Frabjous said:
What distinction are you trying to make with negative overpressure?
Where did I refer to "negative overpressure"?
Kinney et. al. refer to "negative overpressure" only once, in Figure 1.1 C , reproduced in post #53, in the context of the pressure distribution in blast wave where, as explained on p. 90 :
"The overall pressure configuration then consists of an abrupt pressure discontinuity followed by positive and negative pressure phases as indicated by Curve 4 of Figure 6-2. ".
I suspect that the white cloud observed in the Beirut explosion images is the condensation that occurs due to the temperature drop associated with the adiabatic expansion of humid air to below its dew point in the "negative pressure phase" described above. However I can't find any reference to that phenomenon in Kinney or the textbooks I have read.
I would be interested to hear of any source that describes it in a scientific manner.
Wikipedia states (https://en.wikipedia.org/wiki/Condensation_cloud):
"A transient condensation cloud, also called a Wilson cloud, is observable surrounding large explosions in humid air."
And there is a link to this article: https://cen.acs.org/safety/industrial-safety/chemistry-behind-Beirut-explosion/98/web/2020/08.
With this info, perhaps you can find references to the scientific literature you seek.
The condensation cloud is only visible after large explosions, say about 500 kg TNT. It does not get attention because it is transient and a minor part of the explosion.
The condensation cloud has a smooth surface, marked by the transition to lower pressure. It appears to expand in place, from the air, without mass flow of material. Shortly after, it dissolves back into the air, again without mass movement. What could it be but atmospheric moisture?
https://en.wikipedia.org/wiki/Cloud_chamber#Invention
I am indebted to Wikipedia for its reference to Glasstone, Samuel and Philip J. Dolan. The Effects of Nuclear Weapons, U.S. Dept. Of Defense/ Dept. Of Energy; 3rd Edition (1977) for its analysis of this cloud (also referred to as a "Wilson cloud").
That paper associates the cloud's appearance to the blast wave propagating through humid air, and the cloud being formed in the "negative phase" of the blast wave where the air pressure drops below the ambient pressure, as illustrated on p.84 :
Figure 3.11 from page 84: two stacked plots of overpressure (top) and dynamic pressure (bottom) against time at a fixed location after a blast, showing positive and negative phases separated by wind reversal and air flow ceasing markers.
and, on p.43:
"During the compression (or blast) phase, the tem-perature of the air rises and during the decompression (or suction) phase it falls. For moderately low blast pressures, the temperature can drop below its original, preshock value, so that fi the air contains a fair amount of water vapour, condensation accompanied by cloud formation will occur"
It is left for the reader to connect a) the existence of the temperature drop with that associated with the adiabatic expansion of gas, and b) the formation of the cloud due to the temperature falling below the dew-point of the humid air, but I think the formation of the cloud is well explained.
The mystery for me now is the source of this "negative phase". The presence of the overpressure is easily imagined as the result of the rapid expansion of the hot detonation gases . But what is the source of the negative phase, where the pressure drops for about the same duration as the compression phase, and only starts to appear at some time and distance from the detonation?
Line graph of overpressure in air against distance from explosion, showing six curves f1 to f6 at successive times; each peaks sharply then decays, with a small negative dip below baseline after the wave front.
It is referenced in both Kinney and Glasstone, but is not explained.
Search for info on blast waves:
https://en.wikipedia.org/wiki/Blast_wave
"In fluid dynamics, a blast wave is the increased pressure and flow resulting from the deposition of a large amount of energy in a small, very localised volume. The flow field can be approximated as a lead shock wave, followed by a self-similar subsonic flow field. In simpler terms, a blast wave is an area of pressure expanding supersonically outward from an explosive core. It has a leading shock front of compressed gases. The blast wave is followed by a blast wind of negative gauge pressure, which sucks items back in towards the center. The blast wave is harmful especially when one is very close to the center or at a location of constructive interference. High explosives that detonate generate blast waves."
Graph titled Example Friedlander Waveform plotting pressure in kPa against time in ms: sharp rise to 70 kPa at 0 ms, decay crossing zero near 100 ms, negative dip to about -14 kPa near 200 ms, then slow recovery.
I guess my question is along the lines of conclusion 4 of the paper[12] linked in the Wikipedia article :
Slide titled Conclusions listing two numbered points: 3. The trajectory of the spherical piston that drives a centered blast wave has the form of the Friedlander equation. 4. Are there physical reasons why it should be expected that a point source release of energy would generate a spherical piston path of this shape?
It would appear that the Friedlander equation provides a close correlation with the experimental data, but it doesn't explain what appears to me anyway, as wholly counterintuitive, why the high pressure zone of the blast wave is followed by this low pressure zone.
Atmospheric pressure is greater than zero, so there can be positive and negative pressure excursions. After a disturbance, while an equilibrium is being restored, the pressure can be expected to oscillate about atmospheric pressure. The positive and negative phases have the same periodic duration, simply because they are parts of the same oscillation.
Squizzie said:
...but it doesn't explain what appears to me anyway, as wholly counterintuitive, why the high pressure zone of the blast wave is followed by this low pressure zone.
Do you think it's counterintuitive that a region of rarefaction (low pressure) follows every region of compression (high pressure) in an ordinary sound wave in a fluid? If not, shouldn't an impulsive (shock) wave in that fluid similarly have low pressure follow high?
Yes, counterintuitive.
Especially as we now have the Friedlander equation that doesn't have any wave-like e{ix}, e{-ix} components.
