- 37,030
- 16,047
Good example. That result cannot be explained only by current pushing inside the wire.anorlunda said:Forgive me from being almost off-topic, but this thread reminds me of the following true anecdote.
I think that's half the truth only. The other half is that the field affects or causes the current. It's a dynamic relation between the current and the field that works in both ways: current->field but also field->current so it is actually current<->field.snorkack said:Therefore electron movement must be the cause of electromagnetic field, not vice versa.
Dale said:I already told you that I am not suggesting that (see post 79). You are apparently missing some of my posts above. In particular, did you miss the calculation of the speed of the longitudinal waves above (see post 75)? That is pretty conclusive that your approach does not work.
Delta2 said:I think that's half the truth only. The other half is that the field affects or causes the current. It's a dynamic relation between the current and the field that works in both ways: current->field but also field->current so it is actually current<->field.
Dale said:The speed of a longitudinal wave is given by ##\sqrt{K/\rho}## where ##K## is the bulk modulus and ##\rho## is the density. For the electrons in a copper conductor ##K=1.4 \ 10^{11}\text{ N/m}^2##, and ##\rho = 8.94 \ 10^{28}\text{ e/m}^3 \ 9.1 \ 10^{-31} \text{ kg/e}## so ##\sqrt{K/\rho} = 1.3 \ 10^{6} \text{ m/s} = 0.0045 \ c##. Actual signal velocities are much higher than that, and also actual signal velocities depend on the shape of the conductors, the relative positioning of the conductors, and the dielectric used between the conductors. None of that can be explained by the pure longitudinal model.
They are essentially the same. It is not much larger. This should not be too surprising since most of the properties of a material are related to its electrons and how they interact with each other and with the nuclei.jartsa said:Energy needed to force some more electrons into some volume filled with copper is much larger. This latter "bulk modulus" is relevant here.
Dale said:Good example. That result cannot be explained only by current pushing inside the wire.
Yes, that should be obvious. Electrons have very little mass relative to the nucleus and conduction electrons have about the same number density as the nuclei.Byron Forbes said:There are values for the electron density in a conductor that make it the same as the density of a medium that might carry air?
Sure, this is part of a standard classroom exercise, lecture notes, and standard published data:Byron Forbes said:I doubt this very much but I'd be happy for you to point these out to me so that I can see who worked this out and how.
Do you have a scientific paper? :)
