Calculating the Rise of Hot Air in a Solar Dehydrator
  • Thread starter Thread starter tmstauff
    Air Hot Rise
To calculate the rise of hot air in a solar dehydrator, one must determine the air density both inside and outside the tube, considering the temperature and humidity levels. The hot air is at 120°F with 30% relative humidity, while the outside air is at 80°F with 60% relative humidity. By multiplying the air density by the volume of the hot air (40 cubic feet) and gravitational acceleration, one can find the total force affecting the air's movement. This force can then be used to account for friction and acceleration within the tube. Accurate calculations will provide a better estimate than an educated guess.
tmstauff
So for a class I am designing a solar dehydrator and I want to know how fast the hot air will rise out of the dehydrator. For calculation purposes assume the hot air is 120°F @ 30% relative humidity (23 g/m3) and rising through a tube (if necessary assume the tube is 4 in. in diameter), the outside air is 80°F @ 60% relative humidity. In addition assume the hot air has a volume of 40 cubic feet.
If anybody knows how to calculate how fast it will rise through the tube that would be awesome. Otherwise I will most likely doing an educated guess.
Thanks.
How long is the tube?
If you can calculate the air density inside and outside, multiply it with the volume inside and the gravitational acceleration of Earth to get the total force. That will be used for friction and acceleration of the air, with some fraction to determine.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
