How fast will a radiometer spin in a frictionless enviroment?
  • Context: Graduate
  • Thread starter Thread starter carl fischbach
    Frictionless Spin
The discussion centers on the behavior of a radiometer in a frictionless environment, specifically its spinning speed when mechanical failures are eliminated. Participants agree that the radiometer's spin is primarily influenced by the temperature differential between its black and white sides, rather than photon momentum. The consensus is that while a radiometer can theoretically spin faster in a frictionless setting, it would ultimately be limited by the material's mechanical integrity and the presence of gas molecules, which are necessary for its operation. The black side of the radiometer heats up more than the white side, causing a differential that results in motion.
  • Understanding of thermodynamics and temperature differentials
  • Knowledge of radiative heat transfer principles
  • Familiarity with the concept of angular momentum
  • Basic principles of vacuum physics and gas behavior
  • Research the principles of thermal radiation and its effects on gas molecules
  • Study the mechanics of angular momentum in rotating systems
  • Explore the construction and operation of vacuum systems for scientific experiments
  • Investigate the historical experiments and theories surrounding radiometers
Students and professionals in physics, particularly those interested in thermodynamics, mechanical engineering, and experimental physics, will benefit from this discussion.
carl fischbach
If you place a radiometer in a frictionless
environment and eliminate mechanical failure how
fast will it spin?
Since the frequency of c is very high, the
doppler shift of light reaching the white and
black side is virtually negilable, even if the
radiometer is spinning at high speeds,this also
applies to infrared radiation leaving the black
side.Therefore torque acting on the radiometer
doesn't decrease greatly with increasing speed
of the radiometer.Could the radiometer reach
high speeds? Which begs another question is the
the kenetic energy contained in the rotating
radiometer plus the the energy radiated from it
greater than the light energy radiated on to
the radiometer in the first place?
fast will it spin?
Since you're assuming that there are no dissipative forces then the constant torque will keep increasing the angular momentum and thus make it spin faster and faster until the material can't handle the mechanical stresses and it will then fall apart. So it really depends of the material. Otherwise it will spin at a rate at which the speed of all particles is just less than the speed of light. But it would fall apart way before then.
Pete
Radiometers don't spin by the momentum of photons. At some point someone proved that it is a result of the temperature differential in the rarified gas caused by the different colors of the paddles. The black side gets a tiny bit hotter than the white/silver side and the temperature differential causes the molecules to hit at a slightly more oblique angle on one of the sides. However, I do think that if we ignore mechanical failures, and after an infinite amount of time, for all intents and purposes its instantaneous tangential velocity will be the speed of light. That'd be one hell of a radiometer. Btw, carl fischbach, I've PM'd you and you haven't responded to that or to the one (and now two) thread(s) of yours that I've posted in, what's that about? I'm interested in what you have to say about angular momentum and vorticies! I notice a recurring theme here with all your threads, what's with it? You post several threads with topics relating to rotational anything and you never really say anything in them.
What does this mean? What molecules and how does the temperature of the surface affect the angle they hit at? I thought this was in a vacuum, so what molecules are you talking about?
If the cause of motion is a temperature difference then some form of gas must be present to make anything move.
Edit: Rereading the original post I see that he does not specify a vacuum but says frictionless. Wouldn't that imply a vacuum? I would expect air resistance to be the main friction acting.
Yes, if one could make a perfect vacuum in a radiometer, it would quit working. I was assuming that these air molecules where perfectly frictionless. The thing about the angle that I said: I was just repeating from what I remember. I have no idea what that was referring to when I heard it, it didn't make any sense to me now or then. It's too bad I don't know the name of the paper or the guy who wrote it or anything. I am pretty sure this is right, it has to be rarefied or there'd be too much friction, and one can't easily get such a good vacuum that you couldn't get it to work, so maybe this is bunk? I really was sure of it a minute ago.
IIRC, part of the proof was that a radiometer spins in the opposite direction than you'd think. You'd think that there'd be two impulses (hit, rebound) on the white/silver side and one (hit, absorb {no rebound}) on the other. But that would make it spin black side forward, which I remember them (I don't know who) saying that they(radiometers) didn't. I've never gotten around to checking though.
Yes, the spin direction is right on, black side would lead if a radiometer worked off photon-momentum transfer, but if you look on the internet there are a couple places you can find a movie of a radiometer, plus I just took Thermal Physics last semester and the professor had one so I've seen one in real life, and can assure you that the black side trails in a radiometer. The reason is simply momentum transfer by air molecules. A radiometer is simply an enclosed environment and as was said the black side gets hotter than the white side because the white side reflects more radiation, as a result, air molecules striking the black surface pick up more thermal energy and hence "kick off" with more momentum, and by Newton's third law the black side "rebounds" with more momentum. So a radiometer, ignoring mechanical hinderances, and with a very strong heat source (yes, you can spin a radiometer in the dark by putting your hands around it) would at best spin at the terminal velocity of the blades in the interior atmosphere, which would probably be related to the air density and the surface area, but I'm not an aerospace engineer.
Oh good, I'm right!
Correct
One has to completely evacuate the tube instead of leaving a poor vacuum for it to work on radiation pressure alone
Pmb
Just want to add...
In which case it would spin the other way.
  • · Replies 0 ·
9K
  • · Replies 19 ·
  • · Replies 152 ·
11K
