How hard of a Hit force does it take to make a mass jump?
  • Context: Undergrad
  • Thread starter Thread starter MIKES279
    Force Hard Jump Mass
The discussion revolves around determining the height a steel rod or ball will jump when struck by a force. Participants explore the relationship between force, mass, and the dynamics of collisions, with a focus on finding a formula to predict the jump height. The conversation includes considerations of various factors affecting the outcome, such as the nature of the collision and the properties of the materials involved.
  • One participant seeks a formula to calculate how high a steel rod or ball will jump when hit with a specified force.
  • Another participant emphasizes that a single force value is insufficient for understanding collisions, suggesting that mass, speed, and elasticity are more critical parameters.
  • Concerns are raised about the direction of the force, the shape of the colliding bodies, and the nature of the surface affecting the collision outcome.
  • Some participants question the relevance of the force measurement, suggesting that energy, momentum, and collision types (elastic vs inelastic) may provide a better framework for analysis.
  • There is a discussion about the duration of the impact and how it relates to the collision dynamics, with one participant suggesting a specific time frame for the impact.
  • Another participant challenges the validity of the proposed time frame for the impact, indicating that it may be arbitrary.
  • Some participants express frustration over the lack of clarity in the original question and suggest that a change in approach may be necessary to solve the problem effectively.
Participants do not reach a consensus on the best approach to calculate the jump height. There are multiple competing views regarding the importance of force versus other factors in collision dynamics, and the discussion remains unresolved.
Participants note that the approach to calculating jump height may be limited by assumptions about the collision and the definitions of force being used. There is also mention of the difficulty in controlling impact force in practical scenarios.
MIKES279
I am looking for a formula that I can use to find out how high a steel rod or ball will jump up.
If I hit mass M with force F how high will it jump up. If there is a program that would be great.
every thing will be in pounds
So if ball or rod of 10 lbs is hit on the bottem with 14 lbs of force how high will it go up.
These are NOT THE NUMBERS they just to give you an idea of what I am looking for.
What research have you done? What have you found so far?
A single number for force does not tell you much about a collision.
Is that a number for peak force? Or average force? Averaged over what interval? Averaged over time?
For a collision, one would normally want to know the mass of your hammer, the mass of your target, the speed of your hammer and the elasticity of the collision. "Force" would not be an important value. This is just as well, since "Force" is more difficult to predict, measure or control than those other things.
The direction of the force, the relative velocities, the shape of the coliding bodies, as well as the nature of the surface is important to know.
Hitting the rod sideways with a wood block over a flat wood surface is very different than applying a force vertically with a falling foam block over mud.
I want to get some numbers before I make a test unit.
it will be peak time 100th of a sec or so.
Sounds like you don't understand the difference between research and experiments. I didn't ask anything about experiments.
I will change all of them to get the high's I am looking for. I want the formula so I can work out what I need and not waste money. That and after all everything needs to be fine tuned.
This part of the research and none of the books I have deal with this. There was a old dos game with a canonball that did this but that is long ago and far away. LOL
Steel on steel and it is on rails so up and down. Force and mass will change how high is what matters.
Do you know about how high the velocity of the impact wold be?
No i will have to change that to make it work 100th of a sec if that helps. It will be fine tuned i realy want the formula to work it out.
Where does the 1/100th of a second number come from? It sounds made up.
A steel on steel collision at 1 meter per second lasting 1/100th of a second will have 1/200th of a second of collision and 1/200th of a second of rebound. Assuming constant decelleration, that is an average speed of 1/2 meter per second so about 2.5 millimeters of deformation shared between the two objects.
At 10 meters per second, you'd expect 2.5 centimeters (about one inch) of deformation.
Offhand, that sounds high. But I do not know the scale of your objects.
I recommend working in terms of mass, momentum, and kinetic energy, not force and mass. Energy is usually much easier to work with than force. Then you can calculate ideal elastic and/or inelastic collisions to quickly get a rough idea of what you'll be working with.
Khan Academy page about elastic and inelastic collisions: Link here.
If I understand the situation correctly, we have a steel ball or rod of mass M that is suspended in mid air and between two vertical rails.
That mass M receives a vertical impact from another mass of steel.
That collision produces a force F acting upwards during a very short period of time.
Inmediately after that, the mass M slides directly upwards between the rails until reaching certain high, which you are trying to find a formula for, and then stops and perhaps falls back down.
Is the above assumption correct?
That situation remains me of this fair game:
MIKES279 said:
I was not able to find it and I gave more data now
Find what? Look, it's been explained a bunch of time already that the approach you are trying to take doesn't work. If you want to solve this problem you need to change your approach. We could help you figure this out in minutes if you want. Or you can go additional weeks without getting anywhere. Up to you.
[Edit] And also, since you say you want to actually do this.- you can't. There's no easy way to control "impact force". It's just not a useful thing.
Yes just about it.There will be more later.
https://magisterrex.files.wordpress.com/2010/07/blogmousetrap1963.jpg
Ok the rod at point a is moving up at 2.18 feet ^2 at point a how high will it go till it starts to fall back to point a and how long till it starts to fall.
  • Skeptical
What does 2.18 square feet mean? That's an area, not a distance, velocity, or acceleration.
2.18 feet per sec
MIKES279 said:
2.18 feet per sec
That is velocity.
Lnewqban said:
That is velocity.
yes
MIKES279 said:
yes
If that is the initial velocity, this is a projectile problem, considering zero friction among the rails a guides.
MIKES279 said:
yes
Well thank goodness we got that cleared up! :wink:
I didn't read the whole thread, but are you familiar with the Kinematic Equations of Motion for an object that is under the influence of a constant force (the force of gravity down) with no other influences? If you want to calculate the projectile motion of that object given an initial upward velocity, those are the equations you will use. Check out the Wikipedia article for more information...
I will adjust for that
MIKES279 said:
2.18 feet ^2
Guessing that you meant to write that a block is moving upward at 2.18 feet / sec^2, unimpeded by anything other than gravity.
The easy way to approach this from first principles is to start by computing how long it will take for the object to slow to a stop. That result can be obtained by $$t = \frac{v}{a}$$where ##t## is the time it takes, ##v## is the initial upward velocity and ##a## is the downward acceleration of gravity. In units of feet and seconds, the acceleration of gravity is approximately 32.2 feet per second squared.
Since the acceleration is uniform, the average velocity is the mean of the initial velocity and the final velocity. The final velocity is zero, so this simplifies to$$v_\text{avg}=\frac{v}{2}$$where ##v_\text{avg}## is our sought-after average velocity and ##v## is the given 2.18 feet per second^2.
The upward distance travelled will be the product of the two:$$h = v_\text{avg} t = \frac{v}{a} \frac{v}{2} = \frac{v^2}{2a}$$If we use a calculator we can calculate:
Elapsed time: 67 milliseconds.
Average velocity: 1.09 feet per second
Height gained: 0.737 feet = 0.885 inches
  • · Replies 28 ·
  • · Replies 21 ·
  • · Replies 23 ·
  • · Replies 28 ·
12K
