- #1
some bloke
- 278
- 96
- TL;DR Summary
- I want to make a compressed air powered bicycle to get me to and from work, and research has said that a main issue is the cooling caused by expanding gas. How important is it to, and to what extent should I, keep the motor warm?
My plan is to use the compressor at work as a free ride to and from work. I want to install an air tank (a rated one, not an improvised one) onto a bicycle and then run an air motor to turn the wheel (with whatever gears etc needed to make it work). I will probably be using an air tool, such as an air wrench, to run the wheel.
My research has highlighted that the motors will get cold due to the expansion of the gas, and that a heat exchanger is needed to combat this, but I cannot find much explaining why this is an issue? I realize that the oil in a conventional engine needs to be warm to flow correctly, but this can be combatted by using an oil which will operate at low temperatures. I doubt that there would be significant ice build-up inside the motor as it will constantly be moving, but would this be the issue? or will there be a significant loss of power due to the cold environment the air would be expanding to?
In order to prevent the issue, what would be the best option? Will I need an electric heater system to maintain ambient temperature? will the surrounding air be sufficient (I wouldn't be using it in freezing conditions, air temp ~15°C+)? How cold is too cold?If this prototype works, I will be considering converting a 125cc 4-stroke petrol engine to run on compressed air, fitted to a motorcycle. I imagine that this will need a lot more engineering than my initial "strap a windy motor to a bicycle with an air tank" but hey, start small. I've seen a lot of articles about using existing engines to run on compressed air, and they don't mention heat exchangers, so I'm really confused about how necessary they actually are.
Has anyone here done anything like this?To pre-empt a potential flaw regarding recharging - I plan to fit an air motor to a compressor on the bike itself, so that the 200psi compressor at work can charge it up to the maximum pressure of the vessel, which I gather can reach 4500psi on some scuba tanks. If it works I may try to create energy harvesting brakes to charge on downhill stretches, but again, I'm starting with the basics.
