How is sinusoidal current generated?
Sinusoidal current generation is primarily achieved through the interaction of a rotating polarized magnetic field and a conductor, which induces alternating current (AC). This phenomenon is commonly utilized in mechanical systems such as hydroelectric generators and alternators. Additionally, electronic methods like the Wien Bridge oscillator and Waveform Generator ICs, such as the AD9833, can also produce sinusoidal waveforms. The fundamental principle involves changing magnetic fields, which naturally result in sinusoidal currents.
  • Understanding of AC and DC electricity
  • Familiarity with electromagnetic principles
  • Knowledge of waveform generation techniques
  • Experience with electrical engineering concepts
  • Research the operation of Wien Bridge oscillators
  • Explore the functionality of Waveform Generator ICs like the AD9833
  • Study the principles of hydroelectric power generation
  • Learn about full wave rectification and its applications
Electrical engineers, students studying AC theory, and professionals involved in power generation and waveform analysis will benefit from this discussion.
Kenny Bala
I'm delving into AC as well as attempting to understand the various wave forms used in electrical engineering, and I am curious how engineers are able to generate current which alternates in a sinusoidal manner. What specific phenomena allows us to achieve this? Is it a special circuit, or does it have to do purely with the electromagnetics of a current generator?
Thanks!
Circular function relative motion between magnetic flux and conductor.
is the usual mechanical way ( power generating station, alternator in a car)
it can also be done purely electronically
say a Wien Bridge oscillator
Dave
HIgh current inverters are problematic. In my industry we used zero to adjustable low frequency stepping resistors to roughly simulate 3-phase 'alternating' current.
Thanks!
You can also use a Waveform Generator IC to make sine, triangle and square waves (as well as other waveforms). That is how basic signal generator equipment works:
http://www.analog.com/en/rfif-components/direct-digital-synthesis-dds/ad9833/products/product.html
Thanks!
Hydroelectric generators (the kind at big power stations run by water, such as at the Hover Dam) automatically generated AC electricity. For that matter, ANY uniformly revolving power source (wind, water, whatever) will cause a generator to produce AC electricity.
It's producing DC electricity that is difficult ... it is normally done they easy way by first generating AC, which is easy, and then using a full wave rectifier and associate circuit to convert it to DC.
The current alternates in a sinusoidal manner because of the natural geometry involved in a rotating polarized magnetic field intersecting a wire. As said previously, creating DC is problematic. Producing currents requires changing magnetic fields. Simple motions result in sinusoidal currents.
11K
  • · Replies 27 ·
  • · Replies 16 ·
