How is the distance to the x-axis related to the roots of quadratic equations?
The discussion centers on the relationship between the roots of a quadratic equation and their distance from the x-axis. A root, defined as the point where y=0, has a distance of zero from the x-axis. The conversation shifts to the distance from the vertex of the parabola to the x-axis, particularly in the context of the quadratic equation y=ax^2+bx+c. The distance from the x-axis to the vertex is determined when x=b/2a, and this distance is expressed as c-4b^2/a. Understanding this relationship helps clarify how the vertex and roots of the quadratic function are interconnected.
lmamaths
Hi,
How is the roots of a quadratic equation related
to the distance from the x-axis at where
the root is -
where ...
ax^2+bx+c=0
and ...
x = (-b +- SQRT(b^2-4ac))/2
Can someone help me to establish where this
distance relationship to the x-axis and the root
come from?
Thx!
LMA
Mathematics news on Phys.org
Am I understanding this correctly? Are you asking how the roots of a quadratic equation relate to "the distance from the x-axis at where the root is"? A root of an equation, by definition, is a point where y= 0. if y=0, then the distance from the x-axis is 0: the graph crosses the axis there!
Hi,
Maybe I mean't lowest part of the curve to the x-axis, consider:
y=2x^2-3x+2
Thx!
Leo
lmamaths said:
Hi,
y=2x^2-3x+2
Thx!
Leo
I'm not really sure what you're asking Leo. That function has no real roots. If you extend the domain to complex numbers then the function is still zero (both real and imaginary parts) at each of its complex zeros. Real or complex the function is still zero at it's zero's.
lmamaths said:
Hi,
y=2x^2-3x+2
Thx!
Leo
Ah- distance from the vertex to the x-axis.
Given y= ax2+ bx+ c= 0, consider solving by completing the square: write this as a(x2+ (b/a)x+ b2/4a2)+ c- 4b2/a= a(x- (b/2a))2+ c- 4b2/a.
The distance from the x-axis to the vertex is given when x = b/2a and is
c- 4b2/a. do you see how that is connected to the value of x that satisfies the equation?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
