How Is Work Calculated Along a Semicircle in Vector Calculus?
  • Thread starter Thread starter HeisenbergW
    Work Work done
The discussion revolves around calculating the work done along a semicircular path defined by the equation (x-1)²+y²=1, transitioning from the point (0,0,0) to (2,0,0). The force vector is given in a specific form, and the problem is situated within the context of vector calculus.
  • The original poster attempts to convert the semicircular path into cylindrical coordinates and calculate the work done using the dot product of the force vector and the differential displacement vector. Some participants question the correctness of the differential displacement vector and suggest clarifications regarding the coordinate system used.
Participants are actively discussing the setup of the problem, with some providing corrections and clarifications about the differential elements involved. There is an acknowledgment of potential issues with the integration path, as well as the need to specify the semicircle being traversed.
There is a mention of the integration path being ambiguous, as it could lead to different integrals depending on whether the upper or lower semicircle is chosen. The original poster specifies the path must be along the semicircle where y>0.
HeisenbergW
Find the work done along the semicircle (x-1)2+y2=1 from the point (0,0,0) to (2,0,0)
When F=r3cos2φsinφ[itex]\hat{r}[/itex] + r3*cosφ*cos(2φ) [itex]\hat{φ}[/itex]
Work
W=∫F*dr
where dr=dr= dr[itex]\hat{r}[/itex] + rsinφdφ[itex]\hat{φ}[/itex]
I convert the equation of the line (x-1)2+y2=1 to cylindrical coordinates.
Where x=rsinφ
and y=rcosφ
so (x-1)2+y2=1
eventually becomes r=2cosφ
now i plug in this r value into the force vector given, which gives me F=8cos5φsinφ[itex]\hat{r}[/itex] + 8*cos4φ*cos(2φ) [itex]\hat{φ}[/itex]
W=∫F*dr
So now i dot product this with the dr, which is now dr= dr[itex]\hat{r}[/itex] + 2cosφ
sinφdφ[itex]\hat{φ}[/itex] due to the r value I found.
The dot product comes out to be
∫8cos5φsinφdr + 16*cos5φ*cos(2φ)sinφdφ
and because r=2cosφ, dr=-2sinφ dφ
so this is once again plugged into the integral of the dot product, creating
∫-16cos5φsin2φdφ + 16*cos5φ*cos(2φ)sinφdφ
where I integrate from pi/2 to 0, since it ends at x=2 and y=0, but begins at x=0 and y=0
This gives me -4/35, which does not seem to be a correct answer
Any mistakes?
Any help is appreciated
Thank You in advance
The equation is not correct.The second terms has to be rdφ[itex]\hat{φ}[/itex].
And make the vector [itex]\vec{dr}[/itex] different from dr, change of the coordinate r.
ehild
For d[itex]\vec{r}[/itex] I actually left out the second term, which is the elevation angle, since it is constant. I guess I should have clarified that I am using this in spherical coordinates, but I did produce a typo It should be
dr[itex]\hat{r}[/itex]+rsinθd[itex]\varphi[/itex][itex]\hat{\varphi}[/itex].
Which of course just simplifies to
dr[itex]\hat{r}[/itex]+rd[itex]\varphi[/itex][itex]\hat{\varphi}[/itex]
because θ constantly equals pi/2
So you can ignore the lone sin at the end of the force vector, since it goes to one. Yet it still goes to a negative value unfortunately.
The integration path is not clear: You can reach from (0.0,0) to (2,0,0) along the upper semicircle or the bottom one, yielding integrals of opposite signs.
ehild
My apologies, we must go along the circle where y>0
The integral is negative then.
ehild
  • · Replies 28 ·
