How LDD (lightly doped drain) can lower the electric field?
The discussion focuses on how lightly doped drain (LDD) MOSFETs can effectively lower the electric field strength across the device. It explains that the blocking voltage is primarily influenced by the reverse-biased pn junction between the drain and the substrate. A lightly doped drain extends the depletion region, resulting in a reduced electric field strength for a given blocking voltage. While LDD MOSFETs can handle higher voltages, they typically exhibit higher on-resistance and reduced current-carrying capacity.
  • Understanding of MOSFET operation and structure
  • Knowledge of semiconductor physics, particularly pn junction behavior
  • Familiarity with electric field concepts in semiconductor devices
  • Basic principles of doping in semiconductor materials
  • Research the impact of doping levels on MOSFET performance
  • Study the trade-offs between on-resistance and current capacity in LDD MOSFETs
  • Explore the design considerations for high-voltage MOSFET applications
  • Learn about alternative MOSFET structures and their electric field management techniques
Electrical engineers, semiconductor device designers, and anyone involved in the development or optimization of high-voltage MOSFET applications.
uney
thanks a lot!
- The blocking voltage of a mosfet is largely due to a reverse biased pn junction formed between the drain and the body or substrate.
- The voltage at a reverse biased junction is blocked by depletion regions that extend further into the least heavily doped side of the juntion. So the depletion region will be longer, and extend further into the drain, if the drain is lightly doped.
- The longer is the depletion region then the lower is the electric field strength in that region, for a given blocking voltage. Hence a LDD mosfet can block higher voltages but as a trade off would typically have higher on resistance an less current carrying capability.
  • · Replies 20 ·
