How Long Does It Take a Model Rocket to Reach Maximum Height?
3 replies · 3K views
professordad
A model rocket is launched straight upward with an initial speed of 50.0 m/s. It accelerates with a constant upward acceleration of 2.00 m/s^2 until its engines stop at an altitude of 150 m. How long after lift off does the rocket reach the maximum height?
from College Physics by Serway and Faughn
(1) [itex]v = v_0 + at[/itex] where [itex]v[/itex] denotes velocity, [itex]v_0[/itex] denotes initial velocity, [itex]a[/itex] denotes acceleration, and [itex]t[/itex] denotes time in seconds.
(2) [itex]x = v_0t + \frac{1}{2}at^2[/itex] where [itex]x[/itex] denotes the displacement
(3) [itex]v^2 = v_0^2 + 2ax[/itex]
Ok so for this problem I found 2 ways to do it. One of them gives the correct answer (in the back of the book) and the other is off by a little.
The method that gives the correct answer:
So let the velocity of the rocket at the point where the acceleration stops be [itex]v_1[/itex] and the velocity of the rocket at the highest point be [itex]v_2[/itex]. Let the time of the rocket's acceleration be [itex]t_1[/itex] and the time of no rocket's acceleration be [itex]t_2[/itex]. Note that at the highest point, the velocity is 0, so [itex]v_2 = 0[/itex].
Now we find [itex]v_1[/itex]. From equation (3), [itex]v_1^2 - 50.0^2 = 2 \cdot 2.00 \cdot 150[/itex] so [itex]v_1 = 55.68[/itex] m/s.
From equation (1), we have [itex]v_1 = 50.0 + at_1[/itex], so [itex]55.68 = 50.0 + 2.00 \cdot t_1[/itex] and [itex]t_1 = 2.84[/itex] sec.
From equation (1) again, we have [itex]v_2 = v_1 + at_2[/itex], so [itex]-55.68 = -9.8t[/itex] and [itex]t_2 = 5.68[/itex] sec.
The answer is [itex]\boxed{8.52}[/itex] sec.
Ok so here's the other method that I tried but it didn't give the right answer:
Let [itex]d_2[/itex] denote the distance that the rocket travels after it stops accelerating itself. Then, by (3), [itex]0 = 55.68^2 - 2 \cdot 9.8 \cdot x[/itex], so [itex]x = 158[/itex].
So by (2), [itex]x = 158 = 55.68 \cdot t_2 - 4.9t_2^2[/itex].
Solving the quadratic gives [itex]t_2 = 5.49[/itex] sec or [itex]t = 5.87[/itex] sec.
But this doesn't give the right answer :( , help?
I get t=√3100/9.8=5.681 sec.
Yes :) because [itex]\sqrt{3100} = 55.68[/itex] as obtained in my first method, but why doesn't the second method work?
professordad said:
1. .
I also wonder why 2 different values for t.
But if we put displacement=0 then,
0=55.68-4.9t
ttotal=55.68/4.9=11.3632
t=5.68163
