How many B.C. are necessary for first order PDE set?
dragonmount
Hi
I have a set of two linearized integro-partial-differential equations with derivatives of first order (also inside the integrals). How many boundary (initial) conditions should I give for such problem for the solution to be unique? is the 'initial condition that intersect once with the characteristics' still holds? If you can add a refernce that I can use in front of my supervisior it will be great.
A simple problem that reflects my difficulties:
vt+sin(x)vx+f(x)ux=0
ut+sin(x)ux+cos(x)vx=0
Thank you
We're not here to do your research for you, but I will explain one thing to you. You can calculate Riemann invariants for the system you gave and these are constant on the characteristics and so you will only require 2 initial conditions .
You might want to think about the distinction between "boundary conditions" and "initial conditions" and what those differences mean for first order equations.
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
