How much does 1m^3 oxygen at 10 bar weight at 0 degree celsius?
To determine the weight of 1m³ of oxygen at 10 bar and 0 degrees Celsius, the ideal gas law can be applied. The pressure in pascals is converted from bar, resulting in 1,000,000 pascals. Using the formula for density, the calculation yields a density of approximately 440.34 kg/m³ for oxygen under these conditions. This means that 1m³ of oxygen at 10 bar and 0 degrees Celsius weighs about 440.34 kg. The discussion emphasizes the importance of understanding gas laws for accurate calculations.
oeei
How much does 1m3 air (oxygen) weight with 10 bar pressure at 0 degrees celsius?
0 degrees Celsius = 273.15 kelvin
I saw this formula on another thread:
1 atm = 101,325 pascals ~ 1.2 atm = 121,590 pascals
27oCelsius = 300.15 K
Density = (121,590 pascals)/(8.314 * 300.15 K) = 48.72 kg/m3 = 48,720 g/m3
1 000 000/(8,314*273,15)=
1 000 000/2270,9691=440,34
440,34kg/m^3
10 bar
1m3
0 degrees celsius
oxygen
?Thanks in advance
You're given values for P, V and T for the gas.
Do you know any expression that relates these values to each other?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
