How much free energy have we got?
  • Context: Undergrad
  • Thread starter Thread starter technicalm
    Energy Free energy
The discussion focuses on calculating the heat energy harvested from a heating system that draws 5000m³ of air per hour at an outside temperature of 20°C, with an exhaust temperature 6°C cooler. Using the formula Energy = mass * specific heat capacity * change of Temperature, the calculation reveals that the system extracts 36,180 kJ of energy per hour, equating to a power output of 10.05 kW. This demonstrates the efficiency of heat pumps, which can produce significantly more energy than the electrical input required.
  • Understanding of thermodynamics principles
  • Familiarity with specific heat capacity calculations
  • Knowledge of air density at varying temperatures
  • Basic principles of heat pump operation
  • Research the efficiency of different heat pump models
  • Learn about thermodynamic cycles in heat pumps
  • Explore the impact of air density on heating efficiency
  • Investigate methods to minimize system inefficiencies in heating systems
Heating engineers, HVAC professionals, and anyone interested in optimizing energy efficiency in heating systems.
technicalm
Hey all.
Our heating equipment draws air through it at 5000m^3 per hour.
Lets say it's 20degC outside.
The fan pulls the air through and the exhaust air is 6deg cooler.
So we have scavenged that 6degC for our use.
Excellent. So let's pretend there are not any system inefficiencies or losses after that...
As a heating engineer, not a physicist, can anyone please calculate how much heat energy we are harvesting from the 6 degrees out of 5000m^3 of air?
Thank you,
new member, Matt
Science news on Phys.org
I guess it would be...
Energy=mass*specific heat capacity*change of Temperature
air density at 20C 1.2 kg/m^3
specific heat capacity at 20C 1.005 kJ/kg*K
mass = 5000 * 1.2 = 6000kg
Energy = 6000 * 1.005 * 6 = 36180 kJ or of energy per hour, which is equal to...
36180kJ/3600s = 10.05kW of power
wow. quite a lot from thin air!
So that's where the increase in energy comes from in a heat pump, it may only consume 1kw of electricity but mysteriously gives out 3 or 4.
thanks.
  • · Replies 80 ·
13K
  • · Replies 28 ·
