How much work is required to stop a moving block?
The problem involves calculating the work required to stop a moving block, specifically a 3kg block moving at 4 m/s on a horizontal surface. The context includes concepts of work, kinetic energy, and forces acting on the block.
  • The original poster attempts to use the work equation and considers the free body diagram to identify forces and displacements. Some participants question the initial and final kinetic energy values. Others explore the relationship between work and kinetic energy.
Some productive direction has been provided, particularly regarding the relationship between work and kinetic energy, with one participant confirming the calculation of change in kinetic energy. Additionally, an extension of the problem introduces a friction force, prompting further exploration of acceleration calculations.
The discussion includes an extension of the original problem involving friction, which introduces additional variables and considerations for the participants.
ddn87
a 3kg block moves initially at 4 m/s at t=0 and slides on a horizontal surface... Find the magnitude of word that must be done on the block to bring it to rest
I believe we must use the equation w=Fs
I drew the free body diagram and figured that the we have to find the opposing force and the relative displacement. I am having a hard time getting started with this problem. i know that [F]=[N][m] and =[m]
Work done is equal to the change in kinetic energy.
What is the initial KE?
What is the final KE?
okay so i figured that the change in KE=.5 x m x (vf^2-vi^2)
for this problem it would equal 24J
Yes. It is correct.
There is an extention to the problem:
A constant friction force of 2 Newtons is exerted on the block by the surface find the magnitude of acceleration of the block
So I used F=ma where the force i used was 2 and the mass was 3 so id id
2/3 to find the acceleration which is .66666 is this the right method to answering this question?
nm i got the right answer thankyou!
  • · Replies 28 ·
  • · Replies 33 ·
