Fra
- 4,454
- 741
meopemuk said:Ensemble is simply a collection of N identical systems prepared in identical condition.
A theory for reality must I think to a larget extent be formulated in terms of data. Consider how to make a real measurement (taking a certain amount of time each), to probe the measurements on an ensemble and I think the issues I raise should reveal themselves.
meopemuk said:By measuring observable F in each member of the ensemble we generally obtain N different values (unless the ensemble happened to be prepared in an eigenstate of F). QM simply tells us which values appear more frequently and which are less frequent (probabilities).
One problem I have with this is the interpretation of probabilities - A collection of identically prepared systems, which you in principle can prepare and determine the probability distribution as N -> infinity - this sounds scientific and good, but it's not so trivial.
To observe an infinite amount of equal initial conditions is hard, not to mention that it would be infinite time. Some may think that, this is only a practical problem and has no relevance to our ensembles in principle. But I think it does.
QM has move the Newtonian ideals from particle level, to probability level. And that in the probability world every thing can in principle be exactly known. You can know the probability EXACTLY. But this is what doesn't make sense.
If you adapt the probabilistic thinking, the insight that should come is that, by the same token, we can only know the probability to a certain probability as well. And there is probably a relation here with space and time, a kind of uncertainty relation on the ensemble itself. This is another way of reasoning that does lead to suggest the second quantization. But the problem is that, that's not the end. There is nothing that stops the 3'rd and n'th quantization. I am trying to understand this. I think there is in fact a logic here that does explain WHY quantization stops at certain level. I don't have the answer yet, but my point is not to present the answer, just to try to present the question.
This is a question I rarely see aqcknowledged. Why I don't know. That's the other mystery. I have suspected it's because solving it may seem tricky, and there is no point in asking questions we can't answer. That has a point, but I ask it because I do have a vision on howo resolve it. And I think going this way, will incorporate gravity into the information world of QM, in a much deeper way, they will be united from construction. Not by merging two theories that where grown on competely different grounds.
/Fredrik
