How to Build a Circuit for a Linear Hall Effect Sensor?
4 replies · 8K views
chudiandeyu
Hello
I recently bought a linear Hall effect sensor for measuring current, but I don't know how to make the circuit to measure the current, could anybody help me with this? Please tell me the circuit.
By the way, I use the linear Hall effect sensor CSLA2EL by Honeywell.
Thank you very much!
Wow, that's not easy...the first google link I got was labeled "datasheet" but I couldn't find any electrical connection information on it.
But I found a bunch of other datasheets here:
http://www.datasheets.org.uk/CSLA2EL-datasheet.html
and one has a pinout buried deeply in the noise. Now I forget which link I clicked and followed and interpreted, but you should be able to find it too...
It looks like they take a power supply of 8-16v and put out a voltage that is proportional to the current in the loop.
I think this is the datasheet for the Hall effect sensor in the unit. The calibration is in terms of the Gauss field in the toroid gap.
http://sccatalog.honeywell.com/pdbdownload/images/91ss12-2.pdf
See attached pdf for some info on electrical characteristics of current sensor Hall effect holder toroid.
[added] The performance specs for the Hall effect sensor are for operating with a 12 volt dc input. I suggest using a 7812 3-pin regulator. The Hall effect sensor output is an ac output for an ac current input. The null output offset voltage for zero current input is 6 volts ± 0.6 volts. The output appears to be an npn transistor current-sourcing emitter.
Bob S
Charlie Scott said:
This pdf (CS Series Linear Current Sensor Holder Assemblies) is really useful.
Thanx bob,
http://www.halleffectsensor.org/
This is almost a necropost spam post, but the link is actually pretty useful and on-topic for this old thread.
