MHB How to Calculate Arc Length for a 124° Angle in a Circle?
zolton5971
A circle has a radius of 10cm. Find the length s of the arc intercepted by a central angle of 124°
Do not round any intermediate computations, and round your answer to the nearest tenth.
How do I do this?
Mathematics news on Phys.org
You will need the formula:
[box=green]
Arc Length of Circular Arc
The arc-length $s$ of the circular arc, where the radius of curvature is $r$, and the subtended angle is $\theta$ (in radians) is given by:
$$s=r\theta\tag{1}$$[/box]
So, you need to convert the given angle to radians (multiply by $$\frac{\pi}{180^{\circ}}$$), and then plug the given data into (1). What do you find?
Got that one thanks!
The function f is defined by f(x)=x^2+5
Find f(3z)
How do I find f(3z)
You should have found:
$$s=\frac{62\pi}{9}$$
I am going to move your next question to a new thread. :D
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
