How to calculate confidence interval not on t-table
The discussion revolves around calculating confidence intervals for percentages not typically found on the t-table, specifically focusing on 97% confidence intervals under the assumption of a normal distribution with unknown σ and sample sizes less than 30. Participants explore methods and tools for performing these calculations.
  • One participant inquires about calculating a 97% confidence interval without a t-table, questioning if a specific formula exists.
  • Another participant suggests using a calculator capable of computing the inverse of the cumulative t-distribution, providing a Mathematica example for the calculation.
  • A participant expresses confusion regarding terms like "inversecdf" and "studenttdistribution," seeking clarification on the tools needed for the calculation.
  • Further clarification is provided about the official name of the t-table and the meaning of "inversecdf," along with suggestions for using the invT-function on different calculator models.
  • Participants note that the invT-function may not be available on the TI-83+, but alternatives for calculating it are mentioned.
Participants exhibit varying levels of understanding regarding the calculation methods and tools, leading to some confusion and requests for clarification. There is no consensus on a single method for calculating confidence intervals for non-standard percentages.
Limitations include the lack of clarity on the availability of certain functions on specific calculators and the potential need for additional resources to perform calculations accurately.
Notoriousb3
So as the title says. How do you calculate the confidence interval that is not on the t-table. For example how do you calculate the confidence interval for 97%? Assume that it is a normal distribution, you are not given σ and that n<30. Is there a formula? Or should i look for a more specific t-table?:P
You need a calculator that can calculate the inverse of the cumulative t-distribution.
In Mathematica this would be: inversecdf[ studenttdistribution[n-1], 0.015 ] for the lower bound, which is negative.
In this formula n-1 is the so called "degrees of freedom", usually designated "df".
And 0.015 is half of the remaining chance, which is (1 - 0.97) / 2.
Since the t-distribution is symmetric, the upper bound equals minus the lower bound.
You can evaluate this for yourself on the web:
http://www.wolframalpha.com/input/?i=inversecdf[+studenttdistribution[29
Does this answer your question?
Sorry but I don't understand your response what is "inversecdf" and "studenttdistribution". Also what kind of calculator would I need to calculate the inverse of the cumulative t-distribution? I'm rolling on a ti-83 plus and this baby has yet to fail me. Just to be clear, I know how to calculate a confidence interval for the following 80%, 90%, 95%, 98% and 99%. But I would like to know how you would calculate the confidence interval that cannot be solved with the student t distribution. i.e 93%, 97% etc.
The offical name of the t-table is the student-t-distribution-table.
"inversecdf" stands for the inverse of the cumulative distribution function.
To calculate this on a graphical calculator you can use the invT-function.
However it seems this function is not available on the ti-83+, but is available on the ti-84.
But there are ways described on the internet how to do this anyway with the ti-83+.
I found a youtube video describing exactly you problem and how to solve it on your calculator:
And I found another procedure to calculate invT on:
http://www.angelfire.com/pro/fkizer/Instructions/tiusrmanstat83.htm"
  • · Replies 22 ·
