How to Calculate Electric Flux for a Rotated Square in a Uniform Electric Field?
  • Thread starter Thread starter xcvxcvvc
    Flux
The discussion focuses on calculating electric flux for a square in a uniform electric field of 25 kN/C. Initially, the square, with sides of 5.0 cm, positioned in the xy-plane, yields an electric flux of 63 Nm²/C. Upon rotating the square 40 degrees about the x-axis, the flux decreases to 48 Nm²/C due to the cosine relationship with the angle of rotation. When the square's normal is parallel to the x-axis, no flux passes through, resulting in a flux of 0 Nm²/C.
  • Understanding of electric flux calculations
  • Familiarity with trigonometric functions, specifically cosine
  • Knowledge of uniform electric fields
  • Basic geometry of squares and their orientations in three-dimensional space
  • Study the concept of electric flux in varying orientations
  • Learn about the application of Gauss's Law in electric fields
  • Explore the effects of angle on electric flux using trigonometric functions
  • Investigate the relationship between surface area and electric flux in different geometries
Students and professionals in physics, electrical engineering, and anyone interested in understanding electric fields and their interactions with surfaces.
xcvxcvvc
A uniform electric field of 25kN/C is directed parallel to the z-axis. A square of sides 5.0 cm is submersed in this field and initially located in the xy-plane. (a) Determine the electric flux for the square. (b) Repeat if the square is rotated 40.0 degrees about the x-axis. (c) Repeat if the square is moved again and this time its normal is parallel to the x-axis.
(a) 25*10^3 N/C * (5.0*10^-2 m)^2 = 62.5 = 63 Nm^2/C (this is right)
I don't understand how to set up (b) or (c). I'm trying to visualize rotating the square about the x-axis, but doesn't that make only four very slender slices of the square come in contact with the z-axis directed field?
answers:
1. a. 63 N m2/C
b. 48 N m2/C
c. 0
For part b), you can probably see there's a relationship involving the angle. As the square is rotated throughout 90 degrees, the flux that passes through the square gradually decreases to 0. Thus, the trigonometric function you're looking for is cos:
[tex]63\cos{40} = 48[/tex]
For c), the only situation in which the normal of the square will be parallel to the x-axis is when it has been rotated 90 degrees about the y-axis. Thus it no longer lies in the xy plane and no flux can pass through it.
LOL i thought the surface was a cube and i became really confused. Thanks, you helped. I completely understand it now.
  • · Replies 30 ·
