How to calculate increasing force
  • Context: Undergrad
  • Thread starter Thread starter Fizzics
    Force Increasing
3 replies · 1K views
Fizzics
We have a 'T' bar shaped frame with a pulley wheel at each end then a wire passing across the pulleys with a 10 kg weight attached to each end making each side perfectly balanced.
If we were to physically pull down the weight on one side thus upsetting the balance against gravity, could the force used to do this be calculated in an equation?
Ignoring friction, any non zero force will upset the equilibrium.
A single smote of dust on one side means the forces no longer cancel and acceleration will occur.
Not without further information. Specifically you need to know how fast you accelerate the weights. If you move them at constant velocity the required force is zero (assuming there is no friction).
