How to Calculate Mutual Information for a Die Roll on a Leaning Table?
  • Context: Graduate
  • Thread starter Thread starter mathguy2009
    Information
The discussion revolves around calculating mutual information in the context of rolling a die on a leaning table. Participants explore the relationship between the die's outcome and its position on the table, examining the implications of their calculations and interpretations of mutual information.
  • One participant describes a method for calculating mutual information based on observed frequencies from rolling a die on a leaning table.
  • Another participant points out a potential misunderstanding regarding the distinction between sample data and the parameters of a probability distribution.
  • Concerns are raised about the validity of the mutual information calculation, particularly regarding the assumption of independence between the die's outcome and its position on the table.
  • There is speculation about whether the mutual information could indicate if the die is loaded based on the results obtained.
  • One participant questions the interpretation of the mutual information result, suggesting that it may not be small if the die's outcomes are indeed independent of its position.
  • A reference is made to a source indicating that small sample sizes may lead to overestimation of mutual information.
Participants express differing views on the interpretation of mutual information results and the appropriateness of the calculation method used. There is no consensus on whether the calculations are "correct" or the best approach to estimating mutual information from sample data.
Participants note that the relationship between the die's outcome and its position may not be straightforward, and the calculations depend on the assumptions made about the underlying probability distributions. The discussion highlights the complexity of estimating mutual information from sample data.
mathguy2009
Hi all,
I had a question about calculating mutual information, a topic to which I am very new. Consider the following hypothetical situation, in which I describe the entire process from what I understand:
Suppose I had a normal die (sides numbered 1-6) that you roll on a leaning table. I draw a line on the table so that the line divides the higher and lower halves of the table. Now, suppose I wanted to calculate the probability that I would roll a 5 on the upper half of the table. So, I begin by drawing a table like such:
-----1----2----3----4----5----6
High
Low
Then I perform 100 trials and record how many times a certain number was rolled on the higher or lower half of the table:
High_2____5___7___10___1___8
Low_11___6___8___12__20___10
To calculate the joint probability distribution P(roll, position), I would simply divide by the number of times the die was rolled (100 times) to produce the following table:
-------1------2------3------4------5-------6
High_0.02___0.05___0.07___0.10__0.01___0.08
Low_0.11___0.06___0.08___0.12__0.20___0.10
To calculate the marginal probabilities, I sum the rows and columns:
P(roll) = (sum(col 1), sum(col 2), ..., sum(col 6)) = (0.13, 0.11, 0.15, 0.22, 0.21, 0.18)
P(position) = (sum(row 1), sum(row 2)) = (0.33, 0.67)
Lastly, I calculate the mutual information of the data set (for an article on mutual information, see http://en.wikipedia.org/wiki/Mutual_information) using the following formula, using a base-2 logarithm to obtain an answer in units of bits:
MI(roll#; position) = [itex]\sum[/itex]roll#[itex]\sum[/itex]positionP(roll#, position)log2[itex]\frac{P(roll, position)}{P(roll)P(position)}[/itex]
The number I get is 0.1206 bits...I suspect I did something wrong somewhere along the way, since this number is suspiciously small, but I cannot find my mistake. Any suggestions/corrections would be very much appreciated. Thanks in advance!
The most fundamental mistake you are making is to confuse the idea of "data from a sample" with the idea of "parameters of a probability distribution" from which a sample was selected.
The formula in the wikipedia article on mutual information is a formula that would be applied to to a probability distribution. What you did is the natural way that one would would estimate the mutual information from a sample. You used the observed frequencies of the dice results as their probabilities. When you contemplate your results you have to think this way:
I'm using a sample to estimate the true probabilities. The frequencies in the sample are unlikely to exactly match the true probabilities. What sort of distribution of errors between the estimated mutual information and the true mutual information should I expect?
Sometime the best way to estimate things from a sample is to use a formula that does not look like the corresponding formula involving the parameters of the probability distribution. I don't know the best estimation formula for mutual information.
One way you can try to answer this is take samples from various probability distributions using a computer simulation and see how the estimated mutual information varies from the truth when various ways of estimating it are used.
You say that your calculation produced a number is "suspiciously small", but if this were a problem from a textbook, one would expect the mutual information to be zero because in a typical textbook setting, the way the die lands would be independent of where it landed on the table. Why do you think the number is too small? Is the thrower attempting to manipulate how the die lands and do you expect him to be more successful on one half of the table than the other?
Thanks for the reply, Stephen. I did suspect that the die number and the position on the table were unrelated, but wasn't 100% sure. So, in a perfect world/after an infinite number of trials, the mutual information would have actually approached 0 bits, correct?
I am actually working with some large amounts of data in a project in which I believed two random variables involved are highly related, yet I was getting smaller numbers than in this little example here. So I suspected that perhaps my calculations were incorrect; but, if I understand you correctly, my calculations were indeed correct, but my interpretation of the results was wrong.
Interesting side note: could we tell whether the die is loaded, based on how much mutual information we obtain?
That would depend on how you define a perfect world!
You didn't understand me. What would it mean for your calculations to be "correct"? You seem to think there is only one "correct" way to estimate something from data. That isn't true. The definition of mutual information (which is given in terms of probabilities) certainly suggests that we can try estimating mutual information by plugging in observed frequencies in place of probabilities. But it isn't clear this is the "correct" way.
This link says that for small samples, the calculation you are using will, on the average, overestimate mutual information:
http://robotics.stanford.edu/~gal/Research/Redundancy-Reduction/Neuron_suppl/node2.html
My guess is that for large samples, your method is OK, but I haven't tried to prove that.
  • · Replies 32 ·
  • · Replies 16 ·
