How to Calculate Oil Pump Velocity?
The discussion revolves around calculating the velocity of oil in a suction pipe (pipe A) and a delivery pipe (pipe B) in a pumping system. Participants explore the application of Bernoulli's equation and the continuity equation in the context of fluid dynamics, specifically focusing on the relationship between pressures, velocities, and pipe diameters.
  • Homework-related
  • The initial problem statement includes parameters such as pump head, pressures in both pipes, vertical displacement, total head loss, and oil density, which are essential for the calculations.
  • One participant attempted to use Bernoulli's extended equation but expressed confusion regarding the velocity relationship between the two pipes, suggesting that the velocity in pipe A is half that of pipe B, which they found counterintuitive.
  • Another participant pointed out the absence of the continuity relationship in the calculations and questioned the plausibility of a calculated velocity of 14 m/s for the system.
  • A later reply acknowledged a mistake in the manipulation of the Bernoulli equation, highlighting a misunderstanding regarding the relationship between the velocities of the two pipes.
Participants have not reached a consensus on the correct approach to the problem. There are competing interpretations of the application of Bernoulli's equation and the continuity equation, with some expressing uncertainty about the calculations and others pointing out potential errors.
Limitations include potential misunderstandings of the continuity equation and the manipulation of Bernoulli's equation. There are unresolved mathematical steps and assumptions regarding the relationship between velocities in the two pipes.
Gazza-85
This problem is regarding an oil suction pipe, pipe A is the the suction pipe and pipe B is the delivery pipe. There is a pump in between which supplies a head of 11.3m. The pressure in pipe A is atmospheric and the pressure in pipe B is 850kPa. The vertical displacement is 0.8m, total head loss in the system is 0.44m and the density of the oil is 850kg/m3.
If the diameter of pipe A is twice the diameter of pipe B, calculate the velocity in pipe A.
None given... I have tried using Bernoulli's extended equation
Pin/ρg + vin2/2g + zin = Pout/ρg + vout2/2g + zout + Hlosses - Hpump + Hturbine
I initially tried to rearrange the the mass equation by subbing in piD^2 / 4 for area and rearranging to discover the relationship between the velocities in the two pipes with the diameter difference. It seems to be a dead end as my workings suggest the velocity for pipe A is half that of pipe B which doesn't make sense, considering the pressure increase is massive in pipe B. I expected the velocity to be higher in the pipe with lower pressure... Maybe my calculations are incorrect.
Another attempt included entering all of the data into bernoulli's extended equation and rearranging. I could only get as far as 'V_in - V_out = 1.62 (approx)' which is another dead end.
The final attempt consisted of suggesting that Pin/ρg + vin2/2g + zin = the sum of heads which, when rearranged, produced a figure of 14.77 m/s for V_in. Extended workings for this solution are written in my report but I am not convinced...
Thanks for reading, this is my first post so please let me know if I can improve anything. I could attach photos or word documents of my calculations if necessary/possible.
I hope someone can give me a push in the right direction, thanks again.
In your description of your calculations, I don't see any mention of the continuity relationship. Is this what you mean by the 'mass equation'?
A velocity of 14 m/s seems rather high for a liquid piping system.
Perhaps you should post the details of what you consider your 'best' calculation.
Hi there, thanks for the prompt reply, attached is where I am so far.
Yep, continuity relationship and I meant quarter not half :/
You've made a major mistake in your manipulation of the Bernoulli equation:
[itex]V_{A}^{2} - V_{B}^{2}[/itex] = Mess
but
[itex]\sqrt{V_{A}^{2} - V_{B}^{2}} ≠ V_{A} - V_{B}[/itex]
12K
  • · Replies 20 ·
