How to calculate solar cell efficiency with data in dark?
The discussion centers on calculating solar cell efficiency using data obtained from experiments conducted in both light and dark conditions. The user initially attempted to apply the square method with the IV curve but encountered difficulties due to the data crossing the origin, rendering the method ineffective. It was concluded that efficiency cannot be determined solely from dark data; instead, it must be combined with short circuit current measurements under illumination to develop a theoretical IV model for maximum power calculation. The dark data can only yield the saturation current and ideality factor of the solar cell.
  • Understanding of solar cell IV characteristics
  • Familiarity with the square method for efficiency calculation
  • Knowledge of dark saturation current and ideality factor
  • Ability to interpret exponential equations from graph data
  • Research methods for combining light and dark IV data for solar cell efficiency
  • Learn about the theoretical models for IV characteristics in solar cells
  • Study the calculation of short circuit current under illumination
  • Explore techniques for deriving exponential equations from experimental data
Researchers, solar energy engineers, and students studying photovoltaic systems who are looking to understand solar cell efficiency calculations and the implications of dark and light data on performance metrics.
nbky
Hi mates,
I have to find solar cell efficiency by datas that given. These datas comes from an experiment in light and in dark. I found efficiency in light by square method with IV curve.
But i don't know how to find in dark. The square method doesn't work cos data crossing the origin, no area to use this method.
I made some online research but haven't reached the right way.
Do you have any idea to calculate the efficiency?
I haven't find the solution for 5 hours.now i think there is no "efficiency in dark". I guess it behaves like diode and the "efficiency" is ideality factor. do you agree with me?
If it is so i have new problem:
here the equation: i have voltage and current in my data. others are constant. And what is dark saturation current, i don't get it?
it s me again.i made some progress.
As you know the data is exponential, starts from origin (ectually close to origin). if i get the exponential equation from graph (like y=a*e^b), i could find I0 and "n".
So the n is ideality factor of solar cell. So do you think is it the answer?
I did my work and sent. And i get the feedback and i just want to inform you just in case maybe someone else stuck same kind of problem.
First of all i learned it was a tricky question. You cannot find efficiency just using data in dark. You need to combaine that with at least short circuit current under illumination. Then you have a theoretical model for IV model that you can calculate max power.
with only dark data you can only calculate saturation current and ideality factor which the question ask for from the begining. You can find it from the graph like i just said in the last post.
  • · Replies 16 ·
