How to calculate speed voltage from Maxwell's laws
The discussion focuses on deriving the concept of "speed voltage" from Maxwell's equations in the context of induction machines. It highlights that induced voltage is linked to the time rate of change of the magnetic field and the speed voltage, as described in electrical circuit models. A specific equation from a book on linear induction motors is referenced, indicating that speed voltage is a component of the overall voltage equation. The conversation also touches on the potential influence of reference frames in understanding this relationship. The goal is to connect these theoretical concepts with practical applications in machine analysis.
darkfeffy
Hi,
In classical induction machine analysis, the induced voltage (or curl of the electric field) is equal to the time rate of change of the magnetic field (B) plus the 'speed voltage'. This is understood very easily from electrical circuit models of the machine.
However, going purely from Maxwell's equations (1. div(E) = rho/epsilon; 2. div(B) = 0; 3. curl(E) = -dB/dt; 4. Curl(B) = mu(J + epsilon*dE/dt) ) how can one arrive at the same observation as above?
Thanks
e.
What is "speed voltage"? I don't remember ever seeing that term before, in American English. Perhaps there is a language-translation problem?
Hi Jtbell,
Thanks for your response. I was reading a book on linear induction motors, and therein it was written:
\frac{de}{dx}=\frac{db}{dt} + v\frac{db}{dx}
The first term is referred to as a transformer voltage, and the second, a speed voltage. I want to know how to get this from Maxwell's laws. I recently read something about reference frames; I think my answer lies in that direction.
Best
e.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
